can someone help
Old 06-09-2011, 12:24 PM
EF(go Kart)'s Avatar
Default can someone help
hi i have a eg sedan and i have a problem with it. when it is in park or when it is stopped it idles wrong. the revolutions go from 500 to 1000 and move up and down when in park or like i said when it is stopped at a light can anyone tell me when is wrong with it. i think its my throttle body but i might be wrong. so if anyone can help me.
EF(go Kart) is offline
Old 06-09-2011, 12:28 PM
SpecialK_4182's Avatar
Default Re: can someone help
What makes you think it's your throttle body? Are their any sounds, smells, coming from it? Lots of things can make it idle funny.
SpecialK_4182 is offline
Old 06-09-2011, 12:36 PM
like what bro?
Old 06-09-2011, 12:56 PM
EJ1_CRIS_909's Avatar
Could be the iacv needs cleaning, cooling system has air in it and needs to be bled, tps not calibrated right (only if it was ever removed), or even a vaccum leak could be it.
EJ1_CRIS_909 is offline
that_boy_sammy's Avatar
Like your Idle air control valve(clean it), Fast idle thermo valve(clean it), Vacuum leak(check hoses), TPS Sensor(replace if neccesary), air in cooling system, bad alternator. Check all of those in that order, if one doesn't work move to the next.
that_boy_sammy is offline
Old 06-09-2011, 01:28 PM
Former User's Avatar
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post.
Former User is offline
Newbyyy
11-09-2011 02:17 PM
that_boy_sammy
15
11-23-2009 12:15 PM
DAchiko
11-12-2007 06:43 PM
Kirk@SyndromeAuto
01-17-2007 11:14 AM
The G2 Racer
16
01-23-2003 05:23 AM
Quick Reply: can someone help
