93 Dx loosing coolant
Old 01-05-2017, 06:40 AM
White_EG1's Avatar
Default 93 Dx loosing coolant
So I have a 93 Dx with a b7 that has over 220k miles and ever since a couple of months ago it has been loosing a good amount of coolant when driving.
First 5-10 mins of driving it's good, but then it starts smoking. The leak is coming from behind the motor it seems like? But when I open the hood it's like coolant is everywhere on the transmission side. The car does not overheat.
Would this be a faulty thermostat, leaking coolant sensor, or heater core? The heater does not work.
I replaced the lower radiator hose, no coolant in oil or vice versa.... Kind of stumped. Can't find the leak because when I clean it off and wait for it to happen again it leaks so much you can't tell from where.
Old 01-05-2017, 09:34 AM
Premium Member
94 Civic Si's Avatar
Default Re: 93 Dx loosing coolant
There a few coolant lines behind the engine/under the intake. You better take a look from underneath...
Old 01-05-2017, 10:56 AM
Fish Twig
tony_2018's Avatar
The heater core hoses, the iacv. Those are the only 2 locations to look.
Old 01-05-2017, 01:36 PM
mk378's Avatar
Is the heater supposed to work? Heater not working is one of the first signs of low coolant. If coolant is leaking it will eventually overheat. Use a pressure tester to put the system under pressure while cold so you can try to spot the leak.
Behind the engine, as well as the heater hoses there is a U-shaped bypass hose, several small hoses around the intake, and the metal pipe that goes from the thermostat to the water pump. As previously noted, all are best seen from underneath the car.
Old 01-06-2017, 05:08 AM
White_EG1's Avatar
Well it should work, it has all the LX options. I tried to bleed the coolant when I did the lower rad hose, but it took a abnormal amount of coolant I got thru a whole gallon and it wouldn't even reach the rad neck then I got a hunting idle which I think was due to the coolant not being bleed right.
Old 01-06-2017, 05:32 AM
mk378's Avatar
I meant, the heater hasn't been removed or bypassed etc.
It's pointless to try to bleed a leaky system. It's just going to leak out.
Drive the car up on ramps and turn engine off.
Connect a pressure tester and put the cooling system under pressure. Find the leak. Look from under the car if necessary.
Fix the leak.
Fill and bleed the system.
Barmaleyka
Acura TL, RL & ZDX
06-03-2017 11:15 PM
Jamie65
Honda Civic (2001 - 2005)
02-16-2017 11:58 AM
Jayzdb1
Acura TL, RL & ZDX
08-01-2011 06:05 AM
SpazMan
06-12-2008 10:22 AM
msmithgsr2131
02-19-2006 08:39 PM
Quick Reply: 93 Dx loosing coolant
