92 Civic Si -- intermittent wipers don't work. Where is the ICU exactly?
all i see under there is the thing for the cruise control it looks like a icu but im not sure if it is
Former Moderator
Re: cant find icu where is it exactly
Didn't know if you meant ECU, ICM, etc. ICU isn't a really common problem/discussion in this forum, so sorry for my brainfart.
What exact year/make/model?
...and just curious why are you looking for the Integrated Control Unit? Having a problem?
Cool Cool Island Breezes. BOY-EE
The ICU on 92-00 civics and 94-01 integras is on the back side of the cabin fuse box. It's plugged into the fuse box. It's a white square about the size of a pack of cigarettes. I think it's there on DA's as well.
I have one or two for sale, BTW.
fm
oh its on the other side of the fuse box **** thats so hard to get to is there any instructions on how to take it off? just need to swap it my int wipers dnt work n narrows it down to that 92 si
Take your kick panel off. Remove the 10mm bolt that holds your fuse box in place so you can get behind it easier. You'll need to take the plug out of the ICU which isn't too hard to do. It's also helpful to remove the other plugs from the back of the fuse box so you can get better access to it. Once you've got them out, use a flat blade screwdriver and start gently prying from one side, then the opposite side, and keep at it a little bit at a time until it finally comes out. It's a real PITA, but it will come out. You'll be lying upside down under the dash for awhile, so put some padding on the floor and maybe a flashlight so you can see what you're doing.
fm
fm
I removed my driver's seat to make errthang easier. Its 4 bolts and a plug. You'll be happy you did.
hey which i need a icu with int and rear wiper which icu can i use the integra?? i see these on ebay but i dnt kno if it has the int n rear wiper wat do u think http://shop.mobileweb.ebay.com/searc...=0&y=0&cmd=SKW
Re: 92 Ciic Si -- cant find icu. where is it exactly?
Stop replacing parts at random. Test the wiper switch on the steering column. Then do the relevant ICU input tests described in the service manual.
Re: 92 Civic Si -- intermittent wipers don't work. Where is the ICU exactly?
look i tested the wiper switch with a new one and it didnt work i said i narrowd it down in my first post i just need the question that i need a icu with int and rear wiper which icu can i use the integra?? i see these on ebay but i dnt kno if it has the int n rear wiper wat do u think http://shop.mobileweb.ebay.com/searc...=0&y=0&cmd=SKW
How do you know your ICU is bad? Did you do the ICU input tests for the intermittent wipers that I posted? The problem could also be a bad wire or even a bad wiper motor.
