Different kinds of Head Bolts/studs
Old 01-17-2011, 12:36 PM
Tong.Y's Avatar
Default Different kinds of Head Bolts/studs
would ARP head studs be the best way to Aline the head and gasket?
Old 01-17-2011, 12:37 PM
Tong.Y's Avatar
Default Re: Different kinds of Head Bolts/studs
is the top one main studs and the bottom head studs?
Old 01-17-2011, 12:58 PM
MonkeyMagic's Avatar
no. the little dowels between the head and block align the head to the gasket to the block.
studs do nothing but keep them attached.
you'd have to contact arp and see. but they both look like head studs to me. top being the typical arp style. the bottom being oem style.
Old 01-17-2011, 01:17 PM
Tong.Y's Avatar
i know that but would it also be a good way to line up the head when putting it down and attach them?
Old 01-17-2011, 01:21 PM
i guess if you really want to..
Old 01-17-2011, 02:14 PM
Seagull Management
94EG8's Avatar
Top are studs, the bottom are bolts. Headstuds don't stretch the way headbolts do, and while the dowel pins do align the head and the head gasket headstuds do make absolutely sure you don't accidentally catch the side of a hole in the head gasket and enlarge it.
Old 01-17-2011, 02:24 PM
Tong.Y's Avatar
thanks.. i'm going for a OEM bottom end rebuild and i wasnt sure which was best and i thought both were the same.
do you also know the torque spec (b18c1)
Old 01-17-2011, 02:45 PM
Seagull Management
94EG8's Avatar
Headstuds > headbolts
Torque specs will be different with headstuds vs headbolts. ARP includes their own torque specs with the head studs.
Old 01-17-2011, 03:26 PM
canadaek's Avatar
umm headstuds are not in the bottom end ? that would be rod bolts or main bearing cap bolts
( o )( o )
06-02-2012 04:13 AM
Incognito
09-18-2009 12:52 PM
n0pinitr0us
08-19-2005 12:04 PM
9seccivicsi
09-20-2004 10:55 AM
civcexcoupeblack
03-23-2003 01:22 PM
Quick Reply: Different kinds of Head Bolts/studs
