Compression Test on stock ls/vtec, correct?
Old 04-25-2007, 02:52 PM
Teaser's Avatar
Default Compression Test on stock ls/vtec, correct?
I just did a compression test on my stock ls/vtec
Cyl#1 175 psi
Cyl#2 170 psi
Cyl#3 180 psi
Cyl#4 170 psi
I did this test with the engine cold cause it doesn't idle so I couldn't get it to operating temp and I wasn't sure if I was supposed to do it at WIDE OPEN THROTTLE or not so I did it anyways.
Can anyone tell me if these readings are close to what I should be getting and if I am supposed to be doing this test at wide open throttle cause I thought that all you needed to do was disable the ign. and crank the eng. over and I got readings of about 110-120 psi and I thought that was low.
Teaser is offline
Old 04-26-2007, 07:13 PM
Teaser's Avatar
Default Re: Compression Test on stock ls/vtec, correct? (Teaser)
anyone?
Teaser is offline
Old 04-26-2007, 08:55 PM
been there done that
doood's Avatar
1. the engine needs to be up to temp. you're not getting correct readings otherwise.
2. the engine needs to be at WOT while you crank the engine
3. remove all spark plugs not one at a time
doood is offline
Old 04-26-2007, 10:55 PM
blackKready's Avatar
Default Re: Compression Test on stock ls/vtec, correct? (doood)
what kind of pistons are you running?
blackKready is offline
Old 04-27-2007, 03:42 AM
fdavie's Avatar
My understanding is that the absolute values don't matter so much as long as they're not amazingly low (120psi) and as long as they're within 10% of each other.
Notwithstanding that the engine wasn't warmed up, those numbers look fine to me.
fdavie is offline
Old 04-27-2007, 08:38 AM
Silver-RC's Avatar
Hey, I have the same problem with the compression test with my 97 civic EX (stock D16Y8)
Cyl#1 175 psi
Cyl#2 165 psi
Cyl#3 120 psi
Cyl#4 170 psi
The cylinder 3 looks bad, but the motor wasn’t warmed up, so I think that’s a problem, other than that, I think it needs a valve adjustment; I don’t know if that would help since I’m kinda noob with this
What you think?
Silver-RC is offline
Old 04-27-2007, 08:46 AM
Default Re: Compression Test on stock ls/vtec, correct? (Silver-RC)
service limit is usually around 130 i beleve. you might have a bad cylinder dude , warmed up or not. could be a bad rings , could be a valve slightly burnt. hard to say.
Old 04-27-2007, 08:54 AM
EgSalad's Avatar
Default Re: Compression Test on stock ls/vtec, correct? (blackKready)
Your numbers are going to heavily depend on your altitude. As your altitude is higher, atmospheric pressure raises.
Atmospheric pressure <U>at sea level</U> is 14.7psi. Your CR, for example, is 10:1.
14.7 x 10 = 147 psi +/- 10% in each cyl is good.
LS/Vtec with stock pr4 pistons and a b16 head is somewhere around a 9.7:1 CR i believe.
So at sea level, 9.7x14.7 = 142.6 psi.
with your initial posting all cyl being
Cyl#1 175 psi
Cyl#2 170 psi
Cyl#3 180 psi
Cyl#4 170 psi
it looks like your good.
EgSalad is offline
Old 04-27-2007, 09:09 AM
Silver-RC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">service limit is usually around 130 i beleve. you might have a bad cylinder dude , warmed up or not. could be a bad rings , could be a valve slightly burnt. hard to say.</TD></TR></TABLE>
Thanks man, I know is hard to say from this point, but I'm checking the valve on monday, hope it isn't a bad cylinder problem because i'm broke at this moment
Old 04-27-2007, 02:28 PM
fdavie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver-RC &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks man, I know is hard to say from this point, but I'm checking the valve on monday, hope it isn't a bad cylinder problem because i'm broke at this moment </TD></TR></TABLE>
There's also a trick where you pour a little oil into the cyl and re-check the compression. If it goes up a lot = bad rings, if it stays about the same = bad valves.
fdavie is offline
Old 04-27-2007, 08:36 PM
Silver-RC's Avatar
Default Re: Compression Test on stock ls/vtec, correct? (fdavie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdavie &raquo;</TD></TR><TR><TD CLASS="quote">
There's also a trick where you pour a little oil into the cyl and re-check the compression. If it goes up a lot = bad rings, if it stays about the same = bad valves.</TD></TR></TABLE>
Thanks for the tip man , I'll try it and post the results too.
cya
Old 02-21-2012, 03:10 PM
aukaiiki's Avatar
I'm looking at a 2005 Element w/ 2.4L V-Tec and the pressure readings are 190-195-190-175. I was wondering if the last reading was too low or means that the head gasket, rings or valves might be bad?
Mahalo Nui Loa,
aukaiiki sends...
aukaiiki is offline
Old 02-21-2012, 04:06 PM
Seagull Management
94EG8's Avatar
aukaiiki, please create a new thread in the CR-V/Element forum -> https://honda-tech.com/forums/honda-cr-v-element-156/
I would say that last reading is a bit low though.
94EG8 is offline
hellbent86
23
05-02-2011 04:02 PM
skaternak
10
08-09-2009 05:48 PM
gisserhatch
04-28-2006 07:35 AM
lude98SH
11-12-2005 06:21 PM
INTEGRAGATED
01-30-2004 05:37 AM
Quick Reply: Compression Test on stock ls/vtec, correct?
