1999 Civic Dx- Codes P0113, P0131, PO132, and P1129; High and low voltage on same O2?
Old 04-19-2011, 10:06 AM
Arthas's Avatar
Icon6 1999 Civic Dx- Codes P0113, P0131, PO132, and P1129; High and low voltage on same O2?
EDIT:
Fuse 43 was blown under the hood. Its a 7.5 amp. My EM1 dome light is shorting it out I dont know why.
ANYWAYS, these are the codes I pulled.
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage SWAPPED IATS AND FIXED THE PROBLEM.
JK [b]Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage[/b
JK [b]Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage[/b
JK [b]Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected[/b
1. Does code 113 with the IAT mean that the IAT sensor is bad? I believe I have a spare.
2. How does the primary o2 read high AND low?? That doesnt make sense.
3. MAP circuit higher than expected?? Do I also need to replace the map?
Sup all
1999 Civic Dx
OE engine (mod wise)
OE P2E ECU
I got state ref'd in CA so I went back to stock. I took off the P28 and threw on the P2E ECU that I bought on craigslist from a wrecked car.
The car turned on first try and everythings fine. Only problem is; its running a little rich (smells like it has no cat, but it has the factory one.), and when I connect a scanner to it, the scanner doesnt read. I took it to Pep Boys for them to scan and they couldnt scan either. The scanner doesnt even turn on so I dont think the OBDII port is getting power.
I looked around and I dont see a fuse for the port. Is there a fuse somewhere else around the car?
Im in Texas right now but I need to go back to California to fix this ticket.
Old 04-19-2011, 10:36 AM
Former User's Avatar
Default Re: 1999 Civic Dx- It has a CEL, I cant scan it!
Hood fuse 43
Old 04-19-2011, 01:42 PM
Arthas's Avatar
Which fuse is that? The under hood fuse box isnt labeled by numbers.
Its not the F/I EM fuse is it?
Old 04-19-2011, 01:57 PM
The FAQs sticky at the top has printable fuse box diagrams.
No, but next to it.
Old 04-19-2011, 06:29 PM
Arthas's Avatar
Ron, you are amazing with Hondas and I would love to buy you a beer. I just relocated to San Antonio, TX! haha
Can you change the thread title to: "Codes P0113, P0131, PO132, and P1129; High and low voltage on same O2?"
Old 04-19-2011, 06:34 PM
Default Re: 1999 Civic Dx- Codes P0113, P0131, PO132, and P1129; High and low voltage on same
Title changed. Start by resetting the ECU to see whether all codes return.
Old 04-19-2011, 06:45 PM
Arthas's Avatar
Appreciate that.
And done.. Only code P0113 returned. I tried deleting it and after 2 seconds it returned.
Something tells me I forgot to reset my ECU when I installed the O2 sensors and I drove rich all the way to TX from CA. fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
Old 04-19-2011, 06:51 PM
Inspect the IAT sensor and its connector and wires. Is it unplugged?
Old 04-19-2011, 07:06 PM
Arthas's Avatar
You 'da best man. You have no idea how much I appreciate it.
Old 04-19-2011, 07:11 PM
Old 04-20-2011, 03:03 PM
Arthas's Avatar
P0131 and P0505 came on after about 20 minutes of driving.
FML.
chevy383
32
01-11-2014 02:19 PM
D15JDMARIO
03-03-2007 07:39 PM
antonio_pr2003
10-14-2005 09:59 PM
pinoyboy204
11-02-2003 07:06 PM
SIK IN DA HED
11-15-2002 10:59 AM
Quick Reply: 1999 Civic Dx- Codes P0113, P0131, PO132, and P1129; High and low voltage on same O2?
