00 Civic -- Need help wiring my new JVC radio
Old 01-19-2013, 05:53 PM
battmancjz's Avatar
Default 00 Civic -- Need help wiring my new JVC radio
So I got a new jvc CD player from best buy and it came with the wiring harness..now my civic a 2000 lx had the wires cut since I bought it . I found the diagram online and match it with the aftermarket one.
The CD player gets power it response when I put eject button, but no led lights on screen or any lights at all.
I connected the illumination wire orange and white to the power wire just to see if it light up and still nothing . I have notice my cluster dim light stop working any help plsss
Model is JVC kdr330 I bealive
Old 01-19-2013, 05:58 PM
Former User's Avatar
Default Re: radio issues
You'll need to give more information about how you have the unit wired to your harness.
Old 01-19-2013, 06:08 PM
battmancjz's Avatar
Its dark but tommorow I'll write down the wires I have connect from the aftermarket harness to the OEM one. If u happen to know what colors go with what so I can double check tommorow AM I'll appreciate that.I'll post tommorow the exact wire combo I have.
Old 01-19-2013, 06:12 PM
These diagrams may help:
Old 01-19-2013, 06:26 PM
battmancjz's Avatar
Thanks bro I appreciate it..
Do u happen to know to what I would need to connect the orange and white illumination wire the after market harness brings ??
Old 01-19-2013, 06:29 PM
Red/Blk wire in your car harness is power for illumination.
Old 01-19-2013, 06:41 PM
battmancjz's Avatar
Thanks appreciate that
Old 01-19-2013, 07:02 PM
battmancjz's Avatar
OK since my brain is going I got to get this working by tommorow
I have written down how I believe the aftermarket harness and Honda harness have to be connected go ahead and chip in anyone if I have it wrong pls.
First side left is Honda harness - right is aftermarket
HONDA. - AFTERMARKET
Red/black - orange
Blue - white
Gray/black - white /black
Blue/yellow- green
Gray/white - green/black
Red/yellow - purple
Brown/white - purple/black
Red/green. - gray
Brown/black - gray/black
Ground black on black
Main power wires I hope I got this right
Yellow/red. - yellow
White/blue. - red
Old 01-19-2013, 07:07 PM
Post a link to or picture of the wiring instructions that came with your radio. Otherwise, we can only guess.
Old 01-19-2013, 07:19 PM
battmancjz's Avatar
http://www.google.com/search?redir_e...0r330%20wiring
The firstink is the PDF for my stereo ..my stereo did not bring the wiring paper sorry I know sucks I found the diagram thru JVC .I provided the Google link and the first one is the PDF of the stereo.
Old 01-19-2013, 07:50 PM
Your speaker and ground wires were pinned correctly, but your two power wires were swapped and the radio's illumination wire is Orn/Wht not Orn. The corrections are bolded below.
HONDA - AFTERMARKET
Left front speaker
(+) Blue - White
(-) Gray/Black - White/Black
Right front speaker
(+) Red/Green - Gray
(-) Brown/Black - Gray/black
Left rear speaker
(+) Blue/Yellow- Green
(-) Gray/White - Green/Black
Right rear speakers
(+) Red/Yellow - Purple
(-) Brown/White - Purple/Black
Ground wire
black - black
Illumination
Red/Black - Orange/White
Power wires
Yellow/Red - Red
White/Blue - Yellow
Old 01-19-2013, 08:31 PM
battmancjz's Avatar
Wow thanks a lot bro I def apretiate the help I was so lost with the whole wiring I was lossing my mind. Thanks again.
Old 01-19-2013, 08:32 PM
Old 01-20-2013, 07:26 AM
battmancjz's Avatar
Default Re: 00 Civic -- Need help wiring my new JVC radio
OK I just tried the wiring and nothing works..gets no power or no lights...the only way I can hear the CD player get power but no LED is if I connect yellow/red with yellow..but still no lights I double check all wiring and did everything twice and still nothing. When I connected the power lines currently yellow/red - red and white/blue - yellow nothing happens.
I check the fuse box under driver dash instrument lights fuse was blown so I change it...don't know if I should check anything else.
Old 01-20-2013, 07:29 AM
The Grumpiest
grumblemarc's Avatar
There is a fuse under the hood as well. Check that.
If you want to see if the unit itself works, take it out. Take it to the battery and touch the positive wires, constant and switched, of the headunit to the positive terminal of the battery and the ground of the headunit to the negative battery terminal. Does the unit power on?
Old 01-20-2013, 07:38 AM
battmancjz's Avatar
OK buddy I'll do that in case it helps
I test the two power wires from the OEM harness with a test light
The yellow and red has power
The white and blue does not.
Old 01-20-2013, 07:39 AM
The 7.5A hood Back Up fuse (protects Wht/Blu wire) is blown.
And rewire the unit as I indicated in post #11. That shows the correct way to wire the system. Don't rewire it when you have a problem.
Old 01-20-2013, 07:41 AM
The Grumpiest
Check the underhood fuse first. You probably blew it with your first attempts at installing this.
Old 01-20-2013, 07:48 AM
battmancjz's Avatar
Will try it right now thanks I'll be back
Old 01-20-2013, 08:02 AM
battmancjz's Avatar
Yo Honda tech is the ****...thanks guys the fuse from under the hood was blown and now everything works ...thanks to everyone who help me.
Old 09-11-2013, 03:13 PM
aj.pleau's Avatar
This is really helpful, but not quite all of the information I need for my particular problem.
My stereo was stolen out of my 2000 Civic hatchback. It was an aftermarket CD player, and I was hoping to replace it myself. So I bought a Boss thing online...
In the "Electrical Connections" diagram, I have #4 sticking out of my dash, and the plug for the antenna. Then I have a bunch of lose, labelled and colored wires sticking out of the new system. What I'm not quite getting is how to attach these two ends or whether I'm missing a piece? Everything seems reasonable and straightforward, including which wires are supposed to connect where except for this one thing.
Thanks!
Old 09-11-2013, 06:41 PM
AdrianClayton's Avatar
Thanks!
Get an adapter harness to make the install easy and seamless. like this
I don't know if its the right one but any stereo shop or stores that sell radios should be able to get you one.
y2kferari
Audio / Security / Video
02-15-2010 02:35 PM
GetawayInMoscow
12-24-2006 04:34 PM
imskatencrzy
12-25-2005 10:55 PM
tianporn
06-25-2004 05:50 AM
JsCvCVtechSI
03-17-2004 12:35 PM
Quick Reply: 00 Civic -- Need help wiring my new JVC radio
