[FAQ] What parts are interchangeable for all 92-00 Civics?
Old 09-13-2012, 09:40 AM
  #251
The Grumpiest
grumblemarc's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics?
No.
Old 09-13-2012, 10:36 PM
  #252
pc h0's Avatar
thanks for the info! def helpful
Old 09-19-2012, 02:10 AM
  #253
civickiller's Avatar
i have a 96 hatch that needs a new door, are all ek doors interchangeable?
Old 09-29-2012, 11:27 PM
  #254
pelayo114's Avatar
grumblemarc, thanks for the info. I still found that out the hard way...lol
civickiller, As far as I know they are interchangeable from coupes only, not sedans.
Old 09-30-2012, 12:21 AM
  #255
CO671's Avatar
A trick I use to see if serviceable parts are interchangeable goes like this, it may not be 100% accurate, but it helps.
This one is for OEM parts that'll switch over, the second list is for aftermarket brands and parts.
The best site I found this method for is www.HondaPartsNow.com
Go to the part you want, lets say i'm looking for a replacement radiator for my 1999 Civic DX 5speed, but don't have the cash to get a new radiator so I'll check out a friend, local classifieds or a junkyard. I search for the part # by navigating through the site after choosing my vehicle model, year, trim and transmission. Here is the part # for the whole radiator assembly: 19010-P03-505
Don't click on the link of the part # though. You want to copy that part # and paste it into the search box. If you click on the link, you won't be given the results of what other vehicles use the same exact part. If you search for that part # it'll give the results like so:
I go to Rockauto.com, choose the make, year, model and trim of a vehicle. In this case, Honda 1999 Civic 1.6 L4 SOHC. For example, I want to see if a distributor cap is interchangeable and from what vehicle(s) works. I then click the part # which is a link and it'll bring up options. You may have to try this with other products because they will show different options.
This is the method I used to find out that I can use parts from my CRV to my Civic. Instead of purchasing a new A/C idler pulley, I just moved the one from the CRV over.
Also from my experience. 97-01 CRV Clusters fit, front seats fit right in just need to switch the brackets. The clip for the sun-visor goes in as well.
Attachment 534888
Old 09-30-2012, 12:45 AM
  #256
Fnix's Avatar
Default Re: (DOHC4life)
Originally Posted by quickclutch724
Is there a difference between EX and DX? I always thought that was just a trim level?
EX is vtec DX is not I thought
Old 09-30-2012, 12:59 AM
  #257
CO671's Avatar
EX has a different cylinder head yes, (vtec + side mount throttle body/intake manifold) roughly +20hp
Sun/moon roof
tachometer on cluster
e-brake armrest
transmission gears may be slightly different.
rear sway bar
power windows/locks
many other little options and accessories
Old 10-19-2012, 02:24 PM
  #258
Muchos_Dos's Avatar
I have a 94 DX, it doesn't have a tachometer in the gauge cluster. Will the JDM SiR cluster (with tach) plug in play or will it need modification?
Second, I'm replacing the rear trailing arms. Will trailing arms from a 4-door fit on a coupe, and if it's form a EX, LX, etc will they still fit on a 2-door DX??
Old 11-05-2012, 07:21 PM
  #259
Laughing Man's Avatar
I have been searching for the answer to this for over a week...
are 96-00 coupe and sedan seat belts interchangeable?
a page or 2 back someone said honda will replace for free, but i called my local honda dealer and they said no.
Old 11-05-2012, 07:59 PM
  #260
CO671's Avatar
I'm not too sure about that, but here are diagrams for them, the part #'s are different
Coupe , then Sedan.
Old 04-09-2013, 07:18 PM
  #261
GatorFann's Avatar
Curious, I have a buddy what wrecked his 95 teg LS, I can have anything I want off it. I have a 96 civic hatch DX, what can I use from his car? I'd like to add power windows and locks, could I rob his wiring to put in the civic? Not having much luck finding a 96-98 2dr EX to rob the wiring from.
And I already did the rear disc conversion so I don't need those...
Old 04-09-2013, 07:58 PM
  #262
Oh look, I can change this
deschlong's Avatar
^ The motor.
Old 04-11-2013, 06:00 AM
  #263
GatorFann's Avatar
Can't have the motor, he wants to keep it for his next teg, I can have his next teg's motor.
Old 05-31-2013, 12:23 PM
  #264
JDM_WHR's Avatar
Will this midpipe fit on my 99 DX coupe?
http://hondamarketplace.com/showthread.php?t=3148948
Old 05-31-2013, 02:11 PM
  #265
The Grumpiest
Possibly. Next time just link the pic directly in the post.
Old 05-31-2013, 02:20 PM
  #266
JDM_WHR's Avatar
dont' know how to, my bad. Possibly.... dont want to buy for it not to
Old 05-31-2013, 02:30 PM
  #267
The Grumpiest
Neverrmind. It won't fit. I re-read the thing and it says it deletes the resonator. The B-pipe for hatches are longer unless he installed an EX header and cat.
Old 05-31-2013, 05:42 PM
  #268
JDM_WHR's Avatar
thanks bro
Old 06-03-2013, 01:05 PM
  #269
ClutchPapi's Avatar
Will a 95 civic coupe glove box fit a 94 civic sedan ? Help me !!!! Bump
Old 06-03-2013, 01:06 PM
  #270
jbpnoman's Avatar
Coupe , then Sedan.
I can confirm, coupe belts will work in a sedan. I just installed SI belts in my EJ6 sedan with no problems. They still lock up on emergency braking, and hold your body the same way the original belts do.
Old 06-03-2013, 01:09 PM
  #271
sleepyaccord96's Avatar
yes it will.
Old 06-03-2013, 08:16 PM
  #272
ClutchPapi's Avatar
Ok thanks
Old 06-04-2013, 06:01 AM
  #273
Joshka89's Avatar
I doubt the power window stuff would be easy.
You need more than just the wiring, you'd also need the window power motors which are built specifically for the door they go in, you could get the wiring and switches, but you'd need the window motors from the right shaped door, in which case you might as well just get the wires and switches from there.
If you're good at fab work it would work, but I'd say no.
You should grab his seats
Old 06-04-2013, 08:49 PM
  #274
JDM_WHR's Avatar
buddy club spec2 exhaust, come with test pipe, came off a eg coupe
will fit on a 99 DX? I want to put an EX aftermarket header on and add a catalytic converter too
Old 06-04-2013, 10:46 PM
  #275
Ryank327's Avatar
This is something you can just go to the Buddy CLub website and check or give them a call. Also if you are putting a cat on you don't need the test pipe.
Quick Reply: [FAQ] What parts are interchangeable for all 92-00 Civics?
