*SOHC* retard my timing and i think it pulls a little bit better on the highend!
Old 06-01-2004, 06:08 PM
trooper0641's Avatar
Default *SOHC* retard my timing and i think it pulls a little bit better on the highend!
I have a d15b vtec and by advancing my timing i think i have gained better throttle response and some little power on the low end. But when I retard my timing...my idle is kinda off and my car feels kinda sluggish flooring it on 1-3k rpms. But I believe I have feel a little bit more of a highend power on the 2 degrees retard. What do you guys think is best for me? Is there actually proof of this that advance is better than retard? (or the other way around)
2 degrees advance
or
2 degrees retard
This is on a d15b vtec cx w/ i/h/e. I just want the best out of my engine even if ill have to sacrafice crappy gas for 1-2 more hp!
Old 06-01-2004, 06:12 PM
Global Moderator
Jimmy's Avatar
Stock timing=
Old 06-01-2004, 06:36 PM
Risky Business
BauleyCivic's Avatar
Default Re: (Jimmy)
No ****.
Retarding - makes more power up high
Advancing - makes more power down low
1/2 tooth advanced(red) vs 1/2 tooth retarded(blue)
Sure you gain 7peak WHP but you're losing 15 on the low end...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Stock timing= </TD></TR></TABLE>
Old 06-01-2004, 06:41 PM
2+2Door's Avatar
i fully retarded my timing on a accord and it still wont hit the marker....can sumbody help???.....sorry for thread jacking...just didnt wanna waste space...
Old 06-01-2004, 06:53 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: (HeterHsan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeterHsan &raquo;</TD></TR><TR><TD CLASS="quote">i fully retarded my timing on a accord and it still wont hit the marker....can sumbody help???.....sorry for thread jacking...just didnt wanna waste space...</TD></TR></TABLE>
that would be TDC= 0* BTDC....you don't wanna be retarded at all, well, over 0 that is.
I have noticed that with lower octane, 87 or so, withy the p28 and advanced or even stock ignition timing, that on the top end the engine will sort of "fight" against itself. In a way detonating, but not quite.
Old 06-01-2004, 07:52 PM
ritalin
Guest
Posts: n/a
Default Re: (Emerika)
Better yet. I have an aem cam gear on my sohc pos d16. You should concentrate more on making low end power. Your top end will still be there as long as you don't go overboard. Too much topend cam timing and you take away from the bottom end. I found a happy medium right now with a 3 degree advance. I have more low end to mid range power and it still pulls like it always has to redline. Just a thought.
CivicRaping
03-20-2005 06:39 PM
a2nvi3tboy
14
12-12-2003 06:30 AM
abeaujuin
05-28-2003 07:43 PM
sharkey65a
01-15-2003 02:07 PM
Quick Reply: *SOHC* retard my timing and i think it pulls a little bit better on the highend!
