Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
CEL - limp home mode - no code - D3
Old 01-16-2017, 03:07 PM
1122union's Avatar
Default CEL - limp home mode - no code - D3
I am stumped. If I drive in D3 at about 30mph for about 4 miles, the cel will come on (2007 Civic EX). A little after that, the car will go in limp home mode. If I stop the car, switch it off and back on, the light goes out and there is no more problem. When I check for codes, there aren't any.
The same thing will happen if I have it in Drive and travel about 25 miles at 75.
Thanks
RK
Old 01-17-2017, 04:43 PM
97emsedan's Avatar
Default Re: CEL - limp home mode - no code - D3
That's a curious problem. When you started the description I thought it might be your TPS relay or the sensor itself. That would throw the car into limp mode as it did for mine. I am getting the TPS relay replaced. Speed related limp modes are not my strong suit but I would venture to say your transmission control module or a speed sensor might be to blame.
Old 01-22-2017, 02:13 PM
1122union's Avatar
Update. Still have CEL and limp home mode but this time I have codes. The codes are, Po301, 302, 303, 304 and 300. All I have to do to get the CEL to turn off is to turn off the engine and turn it back on. The codes seem to say that I have a miss on all cyl. However, I do not feel a miss.
Any help would be appreciated.
Old 01-24-2017, 03:41 PM
Global Moderator
tech8's Avatar
What is the approximate mileage on the car? Has the spark plugs ever been changed?
Old 01-25-2017, 06:39 AM
DaveSi677's Avatar
hmmm kinda curious... like tech8 mentioned what is the mileage and have the spark plugs been changed?
Old 01-25-2017, 02:42 PM
1122union's Avatar
The plugs and coils were replaced 6 thousand miles ago and the milage is 190K.
thegame7
16
06-21-2013 06:16 AM
lilpastrana
02-27-2007 04:59 PM
CompanyFlow
Acura TL, RL & ZDX
10-26-2006 08:24 AM
1994hondaprelude_dude
10-01-2006 01:51 PM
Draggin99Si
08-18-2003 08:36 AM
Quick Reply: CEL - limp home mode - no code - D3
