Need tips for drive side axle removal
Im replacing ball joint, but im stuck at axle removal from hub. I tried hammering it out with taps on the spindle, I tried using a hub puller tool with airgun and still can't loosen it. Im trying to be as careful as possible to not harm anything in the transmission.
Re: Need tips for drive side axle removal
yeah, I've pulled them off once a corolla and remember it being easy to do. Ive been soaking the axle with PB Blaster all day and been hitting it with a 2lb rubber mallet a few times see if it breaks it loose. I'm letting it soak overnight, if I can't remove it in the morning I'm going to have to remove it from the transmission and take it to a shop so they can press it out.
Mr. Giggles
01-23-2007 06:15 PM
