removing axle from hub.
Old Oct 29, 2005 | 04:34 PM
DubyaAye's Avatar
Default removing axle from hub.
im having a hard time taking my driver axle off. i tried hitting it with a hammer and it barely moves. i tried wd-40 and hond parts washed and other kind of lubricant and it still dont work. does anybody have any suggestions?
Old Oct 29, 2005 | 04:54 PM
spoonfedcrx's Avatar
im assumign u took the axle nut off right? take a big *** hammer and place it up against the end of the axle, then take a bigger hammer and hike up ur skirt and start wailing on it.
Old Oct 29, 2005 | 05:18 PM
flip1199's Avatar
Default Re: removing axle from hub. (DubyaAye)
****.. i'm having a major brain fart and cant remember the name, but did u remove the lower cotter pin and nut on the bottom of the hub assembly so you can pull the brake forward?
Old Oct 29, 2005 | 05:38 PM
DubyaAye's Avatar
Default Re: removing axle from hub. (flip1199)
everything is removed. just need to pull the axle off from the hub.
Old Oct 29, 2005 | 05:45 PM
rainforest's Avatar
i assume you are not near a compressor because you could hit it with an air hammer in the recessed part. but you could fit somthing into the recessed part and hit it with a hammer while the knucke was pulled away from the trans
drigo951
Honda Civic (2001 - 2005)
May 19, 2014 08:42 PM
aowpsycho
Aug 30, 2009 07:11 PM
Endo-land
Sep 5, 2007 06:42 AM
Mr. Giggles
Jan 23, 2007 06:15 PM
GarageAlchemist
Jul 27, 2006 03:04 PM
