Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help - Tire Pressure
Old 09-19-2006, 08:32 AM
HondaMan78155's Avatar
Default Help - Tire Pressure
I recently replaced two tires on my 2005 DX Civic with Kumho tires because the tire shop did not carry the stock tires. They inflated the new tires to 45psi, which is the max pressure rating for those tires. The two stock tires on my car have a max rating of 51psi and I keep them inflated to 30psi, which is what the manual recommends. Should I deflate the new Kumho tires to match other tires or add air to the stock tires to match the Kumho? Also is it safe to have the tires inflated to the max psi rating?
Thanks in advance!
Old 09-19-2006, 09:47 AM
Miracle's Avatar
Default Re: Help - Tire Pressure (HondaMan78155)
Manufacturers recommendations is 30 pounds all around. That is what I keep mine at.
When you infalte it at it's max pressure, you leave no room for heat pressure build up. The tire has no more room for more pressure due to the heat.
Old 09-19-2006, 02:03 PM
Sanji
toyomatt84's Avatar
There's a sticker on the door gap that you should try and follow for tire pressure, regardless what tire you use.
Old 09-19-2006, 06:59 PM
Default Re: (toyomatt84)
The manual says if you drive at higher speeds then they recommend 35psi instead of 30. Since I do drive on the highways everyday to and from work I decided to increase my pressure to 35psi. Thanks for everyones help!
__oversea
01-12-2010 07:51 AM
fastjimmy
11-08-2007 10:14 AM
CereaLand
09-04-2003 05:37 PM
CereaLand
09-04-2003 02:22 PM
RATEDR
04-10-2002 08:43 AM
Quick Reply: Help - Tire Pressure
