Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Clicking Noise while in Park
Old 02-25-2010, 04:30 AM
11:11's Avatar
Default Clicking Noise while in Park
I just recently bought a clean 2004 Civic LX, and I'm baffled by a clicking noise eminating from the console area next to the parking brake. It only does it when I'm in park, and press on the brake.
Once I'm in drive, it disappears. I've already tried searching, but apparently the clicking noises other people are hearing are different from what I'm experiencing. Any help explaining this would be greatly appreciated!
Old 02-25-2010, 06:16 AM
11:11's Avatar
Default Re: Clicking Noise while in Park
No one else has experienced this on a 7th generation civic?
Old 02-25-2010, 08:40 AM
97twodoor's Avatar
Is the noise coming from inside or outside? Check your exhaust hangers and make sure none of them are rusted off or not in the rubber hangers.
Old 02-25-2010, 09:15 AM
11:11's Avatar
It sounds as though it's inside the car. Listening carefully, leads me to believe it's somewhere around the parking brake handle.
Old 02-25-2010, 12:53 PM
theineffable's Avatar
your automatic has a shifter lockout feature that prevents you from shifting into gear unless your foot is on the brake. when you are in park and you depress the brake, the lockout feature is disengaged (that clicking sound is probably a little solenoid that's disengaging the shifter lockout).
Old 02-25-2010, 01:33 PM
ourbloodykisses's Avatar
this is normal.
Old 02-26-2010, 06:39 AM
11:11's Avatar
Awesome. Thanks guys!
I thought that it might have been some sort of solenoid related to the parking mechanism. As long as it's normal to have it be that loud.
Old 02-26-2010, 06:54 AM
ken9's Avatar
I got civic 02 i hear clicking noise going into reverse, would that be the solenoid too?
Old 02-26-2010, 06:59 AM
97twodoor's Avatar
Does it happen when you step on the brake and shift from park to reverse?
Old 02-26-2010, 07:51 AM
11:11's Avatar
Mine happens under these conditions:
A. The car is running
B. The shifter is in Park
Pressing on the brake pedal while the above conditions are met, I get the clicking noise.
Old 02-26-2010, 08:09 AM
97twodoor's Avatar
Sorry, i was trying to get some more info from ken9 about his problem. But with your car that is a normal sound.
Old 02-28-2010, 07:21 AM
ken9's Avatar
Yes and sometimes i don't hear the clicking noise when putting the car into park then reverse again.. Not sure what's.. I ask a mechanic and he said that normal.. Don't know...
Old 02-28-2010, 12:50 PM
DynastyRacer22's Avatar
thats normal my car does the same thing also
Old 03-01-2010, 03:51 PM
space_eyes's Avatar
Yeah, actually I just noticed this today myself... I don't think that normally it's that loud, to me it sounds like something needs to be adjusted, like something is loose or something...
Not a biggie right but will definitely get the console apart to have a look....
Old 01-03-2017, 02:08 PM
dogfish's Avatar
I started to get the clicking noise after I bleed my brakes. I know it wasn't making this noise before I did the brake flush. WEIRD!
Old 01-04-2017, 05:52 AM
HondaEddy's Avatar
I had this same noise but a little different. It sounds like a muffled clicking in the console/vent area. It happens only when i turn the key to the on position but not starting the car. weird. I link a video of it blow though to see if you have the same thing.
Old 01-05-2017, 10:35 AM
Chuck Robinson's Avatar
Your noise is the Shift lock solenoid releasing the pin in the shift column. The pin prevents the shifter from moving out of park before the brake peddle is pressed. When you bleed the brakes, all of the peddle pumping was causing the the pin to repeatedly engage and disengage. Now you hear it because the grease is probably written off, or the had of the pin is a little warped. One way or another, it is not an issue that I would stress about. My 01 has clicked since day one
Old 06-24-2017, 04:26 PM
digisol's Avatar
My newish HRV after 15 mths has started doing the exact same thing when in the park position, it's a fairly loud audible click noise and the click can also be felt through the gear selector.
Got me stuffed what's going on, but it never did this before today.
The Honda team will probably charge me again for a car fault, so much for a warranty.
Old 04-17-2019, 04:03 PM
Vincent Price's Avatar
Yeah that's what it is but any ideas on fixing it? Mine started when the cruise went out. I changed the on off switch, brake pedal switch, and steering wheel cruise control switch. My cruise still isn't working. Clicks like the guy stated, but if I unplug the cruise control under the hood, it stops; but no cruise.control.. Anybody figure it yet?
Old 09-22-2020, 03:43 AM
Giovanni Smith's Avatar
My 2016 honda Crv has the same clicking sound. It appears only happen when I am in park and neutral. Any other gear, reverse, drive, sport, and low, has no sound. It seems to originate from the drivers side foot well area, and when I felt around, a relay seems to vibrate when the sound omits. I was told it was the MICU computer, but other than that I have not seemingly to had any other problems.
Old 07-13-2021, 11:52 AM
HondaMotorsport's Avatar
Same in my Honda Civic coupe lx 2003 clicking only in park Already changed out sensor and it is still doing it. It seems to cause no harm but I figured I’d post the video anyways so everyone can see underneath then plastic what sensor it is. Changing out the sensor doesn’t do anything.
Old 11-27-2022, 08:15 AM
Christopher1979's Avatar
I have an 03 accord ex 2.4l 4 door sedan been driving it for a while no clicking sound when in park and foot on the brake no after I replaced the back pads rotors and calipers it makes a clicking sound under the shifter plate (pp,r,n,d plate) again never made a sound before also the pedal goes almost to the floor to stop have bled the back calipers still no change and don't know why any info would be a big help
accord0494
11-28-2022 06:54 AM
midnightsun
Suspension & Brakes
02-18-2019 09:23 PM
lazychina
08-20-2008 05:45 PM
djtony5
04-14-2007 06:40 PM
99DXcoupe
09-24-2002 09:28 PM
Quick Reply: Clicking Noise while in Park
