Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Brand new radiator, new thermostat, overheated after trying to run heat.
Old 04-24-2016, 02:24 PM
Nicole.03.Civic's Avatar
Default Brand new radiator, new thermostat, overheated after trying to run heat.
I'm not sure if this is the right place to post this...
Anyways, I have a 2003 Honda Civic. I was recently having some overheating issues. I had the thermostat changed and that did not work. I then had the radiator changed as the mechanic said it was clogged. There were no overheating issues after that for about a half of a week. I took my car from Phoenix to Flagstaff, which is about 150 miles. Once I got there I sat with the car idling and turned on my heat. It blew ICE COLD air and once I started driving again the heater remained blowing cold air, but the temperature gauge went completely hot. I checked the fluids this morning and there wasn't any room to put coolant in the radiator itself, but the overflow tank was completely empty.
Old 04-24-2016, 03:21 PM
Fruitpunchpits's Avatar
Default Re: Brand new radiator, new thermostat, overheated after trying to run heat.
id check that rad again crap could have flowed down from your lines and plugged it again.
Old 04-25-2016, 05:43 AM
NDNV's Avatar
Check for a blown head gasket as these engines are notorious for it.
Old 04-26-2016, 04:03 PM
fcm
Old Fart
fcm's Avatar
Bleed the coolant system. 94
eurocrx
08-09-2010 08:42 AM
martiw2
10-26-2008 08:10 AM
Shintakun
01-26-2008 07:44 PM
master honda tech
09-07-2004 12:34 PM
TurboIntegra
10-26-2002 03:54 PM
Quick Reply: Brand new radiator, new thermostat, overheated after trying to run heat.
