Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Honda Accord oil crush washer question?
Old 05-17-2011, 10:46 AM
spekt's Avatar
Default Honda Accord oil crush washer question?
hi everyone, i have a 05 accord 4cyl lx 4 dr, i have a question about the crush washer that were supposed to change every oil change, there seems to be 2 sides, one has a shiny round side, where the other side has a dull flat side. is there a proper way this is supposed to go on, like flat side sitting against the bolt and round against the oil pan? does it really matter because i did my oil change yesterday and i put the round shiny side facing the drain bolt and the flat dull side is facing the pan, if this is the wrong way, will i get by until the next oil change? thanks everyone.
Last edited by spekt; 05-17-2011 at 10:54 AM. Reason: i asked the question incorrectly.
Old 05-17-2011, 01:00 PM
My Name is Nobody
MSchu's Avatar
Default Re: Honda Accord oil crush washer question?
interesting... I just checked my collection of crush washers in the garage, all I see is a stamping difference between the two sides. I wouldn't think it would matter
Old 05-17-2011, 01:13 PM
BLKFLSH's Avatar
It probably doesn't matter, but I always put the rounded side toward the bolt head, and the flat side against the pan. We bolt up a lot of different things where I work, and the rounded side always goes out, because that way there is less of an edge on the part facing out. Doesn't really apply when the drain bolt covers the entire washer, but I do it that way anyhow.
Old 05-17-2011, 03:11 PM
redbull-1's Avatar
Heehee +1. That's how I do it too.
Old 05-17-2011, 05:56 PM
spekt's Avatar
alright sounds good, i was checking some subaru forums and they say that the flat side on their washers face the drain bolt and the smooth side faces the pan so that way it can get crushed and make a seal, other people tell me it doesn't matter, as long as you have one on there and just make sure to change it once you see any leaks. thanks man
Old 05-17-2011, 06:07 PM
My Name is Nobody
MSchu's Avatar
believe me... you are not putting that much torque on the bolt... and the case is vented so there is no real pressure.
Old 05-17-2011, 06:23 PM
spekt's Avatar
cool, thanks man
Old 05-18-2011, 12:13 PM
Old Member
GoLowDrew's Avatar
X3 (or however many).
I think we are suppose to put 60lbs of pressure on the bolt. But whatever my muscle strength is works fine, and no problem getting the bolt loose, or with leaks. IMO, 60lbs it too tight. One is likely to strip the bolt at 60lbs, as I have, after the dealer did one of the oil changes.
Old 05-18-2011, 01:09 PM
BLKFLSH's Avatar
60lbs?? Wow! The shop manual says 29lbs for the V6, and 33lbs for the I4. These are not lug nuts.
Old 05-18-2011, 01:12 PM
Old Member
GoLowDrew's Avatar
My mistake. I must have read 60lbs from something else.
Old 05-19-2011, 03:12 PM
Kev2010's Avatar
^60 is way to much.
I usually do 30lb, but I rarely change my own oil, as I get free oil changes for any newer honda.
Torino117
10-18-2014 07:31 AM
sleeperhonda
10
08-20-2013 08:18 AM
paawk2000
07-16-2007 07:54 PM
ombl4
05-10-2007 01:42 PM
Hairy Gorilla
04-17-2003 10:51 AM
Quick Reply: Honda Accord oil crush washer question?
