Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Automatic Transmission Fluid change
Old 10-22-2015, 03:30 PM
dk199160's Avatar
Default Automatic Transmission Fluid change
Ive got a 2012 honda accord EX-L v6 Automatic with 55,257 miles on it, and the maintenance minder went off and and its time to change the transmission fluid, when changing the fluid out do I need to change the transmission filter also or just drain and fill the new fluid?
Old 10-23-2015, 11:54 AM
Old Member
GoLowDrew's Avatar
Default Re: Automatic Transmission Fluid change
Just drain and fill the ATF. If this is your first time, I would drain and fill 3X so you can get it all out. Maybe spread it out over 3 weekends. Or do some driving in-between the changes.
Replacing the AT filter is not necessary IMO when considering the life of the car. And also at that mileage. AT filter is a bit difficult in the level of difficulty. Base on my guess of where you are in terms of DIY, I would not change the filter.
theLemur
12-27-2014 01:01 PM
sharpescalade
05-31-2007 12:31 PM
businessmanph
Acura TL, RL & ZDX
09-08-2006 01:57 PM
integracura
05-29-2006 04:32 PM
azncollegeguy
02-24-2005 03:23 PM
Quick Reply: Automatic Transmission Fluid change
