Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 V6 Auto; external transmission filter, ready to change, will i lose fluid?
Old 12-27-2014, 09:47 AM
theLemur's Avatar
Default 03 V6 Auto; external transmission filter, ready to change, will i lose fluid?
I already did a 3x drain/fill on my auto transmission fluid now that the car has 110k miles on it. I think it was the first time the fluid was changed since the drain bolt was covered in metal and the fluid was nasty. I did the drain/fill 2 weeks ago. I now have all the parts for the external filter, and I made sure to get every single o ring and gasket that's needed. However, before I take it apart, I'd like to know if I am going to lose a bunch of transmission fluid by doing this while the fluid is full. I probably should have done it while it was drained, but I didn't think of it at the time.
So, for those of you that have done it, is fluid going to go everywhere if I disconnect that external filter under the airbox?
Thanks
Old 12-27-2014, 12:06 PM
BLKFLSH's Avatar
Default Re: 03 V6 Auto; external transmission filter, ready to change, will i lose fluid?
The filter is on top of the transmission, so you will not loose any more fluid with the transmission full or drained. The filter housing will hold a couple ounces, so a little will spill when you take the filter cover off, but not much.
Old 12-27-2014, 01:01 PM
theLemur's Avatar
Perfect, exactly what i needed to know, thanks so much!
dk199160
10-23-2015 11:54 AM
PoorDad
11-07-2010 10:19 AM
wkdclwnz
09-26-2006 03:56 PM
integracura
05-29-2006 04:32 PM
azncollegeguy
02-24-2005 03:23 PM
Quick Reply: 03 V6 Auto; external transmission filter, ready to change, will i lose fluid?
