Timing Balancer Belt..
Old 03-10-2009, 11:23 PM
V-8 who's Avatar
Default Timing Balancer Belt..
I had a oil leak on my 97 honda accord lx. The leak was coming from the front balance shaft seal. So i had to take the sprocket off and put it back on it which can only go on one way. Then i reinstalled the balance belt and tightened up the balance belt. Now when i car reaches around 3k rpm's i notice a slight vibration coming from the engine..... I am wondering if i missed a tooth on the balance belt? I didnt' have to take off the timing belt b/c it is behind the balance belt so i know its not that........ Any help will be appreciated.......... thanks
Old 03-10-2009, 11:49 PM
AK94GSR's Avatar
Default Re: Timing Balancer Belt..
it is possible that you didnt align both both shafts correctly. the front and rear balance shafts needed to be timed aswell. the marks on the pulleys need to be lined up with the marks on the block
Old 03-11-2009, 05:57 AM
In a Junkyard near you.
Ross 2.0's Avatar
Did you install the retainer too? You need to check the timing on the belt. You're probably a few teeth off.
cavrdave
07-18-2011 09:17 AM
airikkCRX
04-02-2010 08:29 AM
Nathan007
11-28-2008 04:26 AM
JDMtype Eg6
02-18-2007 05:45 AM
JiggaFan
02-21-2003 09:52 AM
Quick Reply: Timing Balancer Belt..
