Replaced Blower and resistor but not blowing hard enough.
Old 08-20-2014, 04:17 PM
theheilious's Avatar
Icon6 Replaced Blower and resistor but not blowing hard enough.
I just replaced the AC blower motor and resistor and the fan speeds sound fine but it's not moving much air out of the vents. This car does not have a cabin air filter and there was very little debris in the blower box when I disassembled it. The Inside/Outside air door does operate properly and the vent controls move what little air flow there is to the correct vents (IE Defrost, Floor, Dash). I just thought before I rip it all apart again, I should ask what I should look for specifically as it moved plenty of air before the motor went bad.
Thanks in advance!!
Old 08-20-2014, 04:22 PM
accordturb96's Avatar
Default Re: Replaced Blower and resistor but not blowing hard enough.
Thanks in advance!!
haha your title is funny. Tell her to wrk harder at it! Anyways did you put all the plastic components back together correctly and tightly? if everything else works well then I would inspect your work on the install maybe the air is going out the back etc
Old 08-21-2014, 12:04 PM
I believe that I did put it all back together correctly and I checked around the junction between the blower housing and the Evaporator box. I didn't feel any leaks. I replaced all the rotted foam at the firewall air inlets and the metal connection between the blower and the evap. so I have a good seal.
The thing is, with the exception of an errant business card, the blower box was empty of debris. I guess I should have done a better job inspecting the evaporator but honestly, I can't think of anything else that would be blocking air flow. The Heater core/AC evap door has been problematic for some time but I guess I have no choice but to tear it all down again.... f'k me.......
Old 08-21-2014, 12:41 PM
UPDATE: I took the blower box out and checked the evaporator coil and it is clean! Now I am at a complete loss to understand why air flow is diminished....
Any other ideas?????
Old 08-21-2014, 01:30 PM
This is my third time taking the blower box out of the car. I really need some help on this!!!! Anybody?????
Old 08-21-2014, 01:39 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
strange, when it's on high speed how much air does it blow? you said the evaporator box is clear? usually crap goes through the blower and ends up in the evaporator box.
Old 08-21-2014, 02:42 PM
Yes, on full speed, there is almost no air flow in either the outside or inside air positions to any of the vents.
Upon closer inspection there was a small amount of debris along the bottom and the side closest to the cabin (opposite the firewall) I cleaned that out and ran a shop vac gently across the coils (I was a H/VAC tech so I know not to damage the coils) but I really didn't hear any debris going down the vac pipe and they weren't really that visibly clogged to the extent that I've seen evap coils get. As a matter of fact, they were surprisingly clean and so was the blower box. What in the heck am I missing here???? How can I deep clean the coils without discharging the system and taking the evap out of the car?
Something else is going on and I need some suggestions as to what else to look for other than the painfully obvious. Not trying to be a d_ck, just frustrated....
Old 08-21-2014, 02:58 PM
Global Moderator
tech8's Avatar
Try switching the blower motor's power and ground wires.
Old 08-21-2014, 04:04 PM
before you do that, see if air is blowing OUT of the cowl with the blower running
Old 08-21-2014, 06:24 PM
Air in through the cowl is the right direction. I checked the blower output before I reassembled the first time.
I saturated the evaporator with cleaner degreaser (because I didn't have any coil cleaner), reassembled it and started the ac with blower on high and ran it for over an hour to 'wet up' the evap and mix with the cleaner. There was a slight improvement in air flow but this thing should be lowing my hair back and it's not. Killin' me.....
Old 08-22-2014, 01:20 PM
OK.... Resolved.... Just so no one will say that I am not willing to admit when I am a complete dumb_ss: Yes the blower power was reversed. I did not know that a centrifugal fan will still blow the correct way when spinning in reverse. It's just a much lower output.
On the positive side:
1) I can remove and install a 90 Accord blower assembly in about an hour now.
2) My evaporator is SPARKLIN' CLEAN!
3)No more sweltering in the hot August Georgia sun.....
Old 08-22-2014, 01:47 PM
Global Moderator
tech8's Avatar
The wiring being switched is somewhat common, especially with aftermarket blower motors that come with bare wires.
Good to hear it was resolved.
Old 08-22-2014, 04:26 PM
Lost Again's Avatar
^ I know I'm late to the party but when I read the first post this was my first thought.
OP - don't feel bad, I've seen/read/done the same thing 100's of times.
Old 10-15-2016, 03:41 AM
pi-piper's Avatar
Guys,
Resurrecting an old thread here,as I ended up in a similar situation.
I noted the fix (reversed the power to the motor) but how exactly is this done ?
Cheers.
Old 10-15-2016, 04:46 AM
poorman212's Avatar
Most aftermarket blower motors come with two "bare" wires coming off the motor. You have to "splice" those to the factory wire harness...just switch which factory wire is connected to the blower motor wire(s).
Old 10-15-2016, 06:29 AM
pi-piper's Avatar
Poorman, your name matches my situation..lol
Thanks for the advice ! I'll attempt a DIY.
Cheers.
Old 04-13-2018, 02:23 PM
Matthew1225's Avatar
Witch direvtion is the fan supposed to spin clock wise or counter clock wise
KristyC
08-31-2015 02:34 PM
fog raw
11-04-2011 05:36 AM
sligoker
09-22-2011 10:45 AM
SedanCruiser
08-01-2007 10:37 AM
TekNinja23
07-11-2003 08:26 AM
Quick Reply: Replaced Blower and resistor but not blowing hard enough.
