need help.. where is no. 1 cylinder position sensor at?
Old 11-29-2005, 03:17 PM
menmy92's Avatar
Default need help.. where is no. 1 cylinder position sensor at?
i did a diagnostics cuz the check engine came on and it said its the no. 1 cyp.. where the hell is that? distributor maybe?
Old 11-29-2005, 05:09 PM
P_Adams's Avatar
Default Re: need help.. where is no. 1 cylinder position sensor at? (menmy92)
Most likely in the distributor, or behind the Ctankshaft Harmonic Balancer Pulley.
Like, for instance; this '94 thru '97 F22B2 (#17)
Crank TDC sensor = Behind Harmonic Balancer Pulley
http://www.hondaautomotivepart...AINER
BUT, in this case (to '93 F22B2 THERE IS NO CRANK SENSOR)
I can be no more precise, you didn't give a year
P
Old 06-10-2013, 03:34 PM
Candice Burcham's Avatar
I have a 1992 Honda Accord EX and it flashed a 9 code which is the no. 1 cylinder position sensor. I have no idea where it is located.
Old 06-10-2013, 11:16 PM
holmesnmanny's Avatar
lil black box shaped sensor inside the distributor....best thing is to pull a junkyard distributor..you will need either a 92 or 93 car year distributor
civic1999si
11-02-2019 06:25 PM
jetlife
09-17-2016 10:43 AM
Ash J. Williams
Engine Management and Tuning
08-08-2012 09:57 PM
Nvious R
10-28-2003 06:27 PM
Quick Reply: need help.. where is no. 1 cylinder position sensor at?
