Help lowering my 99 accord 4DR
I have a 1999 Honda accord LX 4dr and have questions on what i need to do to lower my car since i just put 18 inch wheels on them.
I was wondering if it was better to buy a coilover or get springs and shocks. I also need to know if i need to get a camber kit and anything else. Does the brand of springs and shocks really matter and how much would i be looking to spend to have this done to my car...any advice is appreciated
A camber kit should be purchased and you should get an alignment done any and every time you drop/raise a car, or change the wheel/tire/etc.
Spring/Shock combo is probably your best bet, but they are not height adjustable.
You could buy something like ground control sleeve coilovers and put tokico/agx/etc shocks in there, that's what I would suggest.. Most likely it will run you $600 or so brand new, maybe $350 used.. good luck!
Re: (Trae)
so if i get the shock/spring combo they arent adjustable? and how much would everything cost me with alignment, camber kits, shock/springs or coilovers? whats the best combo to go with a save me money as well as last me
