Help Asap plz:crankshaft pulley came loose car wont start
Old 01-14-2010, 03:29 AM
darkstoner420's Avatar
Icon6 Help Asap plz:crankshaft pulley came loose car wont start
k so i was driving to work last night and the harmonic balancer came loose and shot the timing belt off on the free way i coasted off of ramp onto a back road, pushed the car into a church parkinglot and stuck the keyback in all the way and tightened the crankshaft pulley back down , bought a new alternator belt and popped it on. Now the car wont start it turns over , has spark, checked compression has compression in all cylinders, now im just not sure if my timing belt could jump from it or get messed up from the key coming out? anyone think they could help me i gotta go back down there and fix it once the sun comes up will be much appreciated
Old 01-14-2010, 05:12 AM
jdmwannabee's Avatar
Default Re: Help Asap plz:crankshaft pulley came loose car wont start
make sure your motor is tdc and that your tensioner isn't messed up.
Old 01-14-2010, 06:10 AM
mavvrik's Avatar
check to make sure your CKP is still working. The ckp is in the dizzy I believe
Old 01-14-2010, 06:11 AM
Conan's Avatar
If the key came off the crankshaft, then yeah, the cam drive gear on the crank could have just free spun. Sounds like you basically need to pull your timing belt off and re-install. If it is near time to replace you may as well replace it as it's just as much work. Good write up in the FAQs.
Old 01-14-2010, 06:52 AM
GhostAccord's Avatar
^^^What he said x2
Could also be a good time for a new water pump and a valve adjustment.
Old 01-14-2010, 06:58 AM
awesome time to head to the parkinglot and retime it lol, this outta be a fun task in a parking lot -_-. ill let ya know the outcome when i get back and thanks again
civicseth
11
08-05-2009 06:15 PM
coreyhayman
12-30-2006 05:45 PM
99blackdc2
07-28-2006 07:23 PM
N20civicB18
19
07-04-2004 05:25 PM
Quick Reply: Help Asap plz:crankshaft pulley came loose car wont start
