Dome lights and door courtesy lights dont work
My 93 LX dome light does not work in ON or in the DOOR OPEN position. Also when the door is opened the little lights on the front doors dont light up.
I checked all the fuses near the foot pedal on the drivers side and they are good.
Any suggestions?
I did a search and someone said the dome light fuse is under the hood. Where exactly under the hood is it?
TIA
Any suggestions?
TIA
1 Post
Re: Dome lights and door courtesy lights dont work (mozzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mozzy »</TD></TR><TR><TD CLASS="quote">My 93 LX dome light does not work in ON or in the DOOR OPEN position. Also when the door is opened the little lights on the front doors dont light up.
Any suggestions?
TIA</TD></TR></TABLE>
its in the fuse box, in the back left corner under the hood....they should be marked on the fuse box....my 94 (5th gen) has a similar problme, but mine is most likely do to a short in the wire....itll blow fuses after a dozen "uses"
Any suggestions?
Re: Dome lights and door courtesy lights dont work (fw190bvi)
thxs fw190bvi
changed one (interior light) fuse from under the hood..took a minute and now all lights works..
my buddy said it cld be due to my aftermarket cd player pulling more current. If it happens again he advised me to use a 20 amp fuse (its 15 now).
trex352
01-27-2007 02:50 PM
Tech-Nics
06-23-2006 11:01 AM
ringerracer
21
11-03-2004 07:40 AM
