Clutch Pedal Bracket Loose!!!
Old 08-30-2004, 04:12 PM
JdmAcclude's Avatar
Default Clutch Pedal Bracket Loose!!!
My car won't go in gear. When I press the clutch pedal, it doesn't go in as deep as usual. So I go under the dash to take a look, and the clutch pedal bracket is loose on the firewall, preventing me from depressing the clutch pedal. There are 2 bolts with 12mm nuts on them, diagonal from eachother. One top-left and the other bottom-right. The top-left bolt will not tighten. How do i find the other end of the bolt on the other side of the firewall? Through the engine bay or from underneath the car? Please help....
Old 08-30-2004, 06:19 PM
TxTuner
Guest
Posts: n/a
Default Re: Clutch Pedal Bracket Loose!!! (JdmAcclude)
Which ever is easier for you. Look where the bolt runs through and get a visual image of the bolts position on the other side of the firewall and start looking.
Old 08-30-2004, 09:39 PM
Eddiebx's Avatar
or u can just go look for it from up top where u can actually see it,
its right under the brake fluid reservoiur, where the small clutch fluid reservoir is connected to u will see it all the way down there on the firewall.
Old 08-31-2004, 08:47 AM
Turbowa's Avatar
Default Re: (Eddiebx)
Those 2 nuts that your looking at are part of the clutch master cyl. It may be moving around to much and damaging the master cyl. You may want to see if the master cyl is leaking. DO NOT force the nut on the bolt.
Old 08-31-2004, 07:33 PM
JdmAcclude's Avatar
Default Re: (Turbowa)
Well the problem was that I didn't have a spacer plate between the clutch pedal bracket and the firewall. All cars that originally come 5speed have them. Went to the junkyard...found a spacer plate. ( BTW,the prelude and accord pedal bracket shape is the same). Problem solved. I accessed the other side of the firewall from underneath. My friend held the bolts while I tightened the nuts from inside. (get your minds out of the gutter and stop giggling) So problem solved...thanks for the responses.
nomoshing
09-02-2008 01:48 PM
djmatix
04-26-2007 07:05 PM
Fezzie
13
08-23-2006 01:57 PM
jdm206
12
02-21-2006 03:22 PM
[626]95-GSR
11
03-29-2003 09:13 PM
Quick Reply: Clutch Pedal Bracket Loose!!!
