looking for part numbers
Re: looking for part numbers (nomoshing)
you just reuse your current nuts except for the clutch pedal bracket needs a bolt for the top....you do not need to plug in the sensors for the clutch pedal....ive had two auto-to-manual civics and never had issues....you can start it without pushing the pedal in
the clutch pedal bracket only needs one nut?
which part number is it?
i mean i did find the site already its just i need help because there are so many damn aprts haha
so you can have the gear in neutral and start it without pressing the clutch
but when parked in 1st you have to press the clutch in just like a car that was made a 5swpeed right?
Re: (nomoshing)
look under your hood there is a black block off plate on the firewall to the right of your brake booster. that is where the clutch master cylinder goes. now look under the dash on the left of the steering column there are two nuts holding that block off plate on. remove the nuts then the plate now replace with the master cyl. bolt the pedal assembly to the studs of the master cyl. then you need to find a bolt for the upper part of the assembly its #42 in the pic above. there is a pin that attaches the pedal to the shaft of the master cyl that is held in with a cotter pin.
djmatix
04-26-2007 07:05 PM
GreenMachineRex
26
09-30-2005 08:58 AM
