Honda Accord Type R, vtec not working ***Help***
Old 03-26-2007, 05:00 AM
shamgt's Avatar
Default Honda Accord Type R, vtec not working ***Help***
Hi, i'm a new member and have own a honda accord 2.2 type r vtec.
I have had the car for 2 years now without no problems, it has always been serviced and very well looked after.
Jus recently my engine management light has come on and my vtec only works sometimes...
Can any one shed some light on what the problem is or how i can fix it.
Many thanx
Sham
Old 03-26-2007, 05:13 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: Honda Accord Type R, vtec not working ***Help*** (shamgt)
by engine management light I assume thats the same as a CEL (check engine light)? If so, did you get the code read thats it being stored in the ECU?
Also, the engine you have is a H22A7 right?
Old 03-26-2007, 05:49 AM
shamgt's Avatar
Default Re: Honda Accord Type R, vtec not working ***Help*** (TouringAccord)
yes its the CEL thats on...
how and where can i check this...
also it is the H22A7 engine
Old 03-26-2007, 05:56 AM
H-T Order of Merit
That should be an OBD2 system so you need a scanner to read the code. I assume you are not from the states right? In the states some parts stores will rent out or even read the codes for you for free.
Old 03-26-2007, 01:48 PM
pos_cd5's Avatar
go get the code read and if the person that reads it for you cant tell you what it is, post it here, i have a list of all OBD2 codes.
Old 03-28-2007, 05:58 PM
361 accord's Avatar
whered you get a type R?
Old 03-28-2007, 07:17 PM
JDM.Accord's Avatar
Default Re: Honda Accord Type R, vtec not working ***Help*** (361accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361accord &raquo;</TD></TR><TR><TD CLASS="quote">whered you get a type R?</TD></TR></TABLE>
The m4d t!t3 jDM Hyp3-r ste4Rsh!p y0
I'm sure he's from Europe
Old 03-30-2007, 02:01 AM
shamgt's Avatar
i'm from the Uk, we can get accords in type R here.
I will get the car checked and will put the code on forum so you can let me know what the problem is...
wlanford
02-18-2014 08:16 AM
swertepinoy
10-06-2009 06:40 AM
inzaneN1
12-03-2003 01:34 AM
boosted spoon
07-23-2002 12:08 PM
Quick Reply: Honda Accord Type R, vtec not working ***Help***
