Ac fan and engine fan
when i have my ac on just idling and its like 85+ outside.. the engine temp jumps up and i quickly turn it off... the ac fan works but im not sure if the other fan is working.. when does the other fan turn on???
Re: Ac fan and engine fan (Negronese)
both fans should come on with a/c on .............put a/c on get a big screwdriver and hit the back side of the fan that does not work if it comes on you got a bad motor if not could be fuse, wiring , relay
Re: Ac fan and engine fan (deserthonda)
i was told the other fan turns on when it feels like its heating up...
so if i start my car up right now (cold start) and i turn on ac, both fans should start working???
Re: (deserthonda)
I have the same problem on my 98 accord. Only one of my fans will turn on when i switch on the ac, haven't tried to hit the other fan w/ a screwdriver yet. Hopefully that will get it to start or else i probly have a busted fan motor.
Ok im pretty sure the one fan that wont turn on is messed up. I would hit the fan that didn't move w/ a screwdriver and it will spin although very slowly compared to the other fan, and it wont spin up when I turn the ac on again. Anybody know how much one radiator fan would cost?
Efbucket
09-03-2007 11:55 AM
jazz215
17
07-27-2003 05:17 PM
