96 honda accord engine ground locations
Old 08-24-2013, 07:05 AM
beanznyc's Avatar
Default 96 honda accord engine ground locations
I'm having trouble figuring out the ground locations on my 96 accord lx. I cant really make out the drawing in the helms book. I know one of them connects to the intake manifold which i have confirmed. I know one also connects to the body by the passenger side headlight/radiator area. There is one ground wire that comes off the (-) battery terminal. Where does the wire connect to? A picture would do great justice...
beanznyc is offline
Old 08-24-2013, 07:55 AM
beanznyc's Avatar
Default Re: 96 honda accord engine ground locations
anyone?????
beanznyc is offline
Old 08-24-2013, 11:59 AM
Amber Dawn's Avatar
I have the same model and my battery only has 2 lines coming off the neg. terminal. The little yellow one that connects to the body and the fat black one that connects down kinda in front of the transmission dip stick.
Amber Dawn is offline
Old 08-25-2013, 05:05 AM
Lost Again's Avatar
It would help to know "which" ground location (circuit) you are looking for.......if I had to guess, there are more than 100 ground locations.
Lost Again is offline
Old 08-25-2013, 05:14 AM
GhostAccord's Avatar
On the engine there are a few, in the bay there are a few more. On the engine I cxan think of the one on the power steering bracket, alternator bracket, valve cover and the most important one is the main engine harness ground (G101). That is mounted on the drivers side end of the upper intake manifold. Under one of the bolts on the vacuum "T".
GhostAccord is offline
Old 08-25-2013, 05:32 AM
Lost Again's Avatar
Yes, for the engine there are less - should have read the title better. I was thinking of ALL of the ground locations on the entire car.
Old 08-25-2013, 06:53 AM
Oh yeah, there is probably a ground for every square inch of the chassis...lol
Old 08-25-2013, 09:17 AM
beanznyc's Avatar
I am aware of the "G101" engine harness ground wire which is connected on the intake manifold.
I think i figured it out... the ground locations i was talking about were the battery ground cables, the ones off the negative battery terminal. I think the cable is identified as "G1". One goes to the chassis by passenger side headlight/radiator area and the other one "G1" goes down below on the tranny housing.. Can anyone confirm this?
beanznyc is offline
Old 08-25-2013, 09:42 AM
beanznyc's Avatar
the pic shows "g1" as the ground to the body but there is another cable that im 95% sure goes to the tranny housing but the helms shows differently. When i look at the ground distribution diagram in the service manual it has "g1" as the ground that goes to tranny housing. Do the locations really matter??
beanznyc is offline
Old 08-25-2013, 09:51 AM
beanznyc's Avatar
here it says "G1" is the battery ground that goes to chassis
beanznyc is offline
Old 08-25-2013, 09:52 AM
beanznyc's Avatar
am i reading it wrong?
beanznyc is offline
01celica_gts
11-02-2015 03:08 AM
motor motor
06-09-2013 08:40 AM
steven.shutz
12-10-2011 05:35 AM
LX4CYL
06-05-2003 10:07 AM
S13Koop
08-12-2001 04:21 PM
Quick Reply: 96 honda accord engine ground locations
