96 4door wont start (ignition switch?)
well i have a problem battery is at 14.4 volts and about a year old, turn the ignition switch and fuel pump runs then shuts off and try to start car you get a click and loose all power no dash lights nothing wait a few hours and still nothing so pulled the switch from the column now this is where i need yalls help...looked online and cant find a pin out chart on the plug to get the car running to move out of the way till i get a switch or do yall think it could be something else? thanks mike
MM Gruppe B
Re: 96 4door wont start (ignition switch?)
If you have the switch out, take the switch apart.
Look at the contacts, and verify they are clean, and no arcing. If there is arcing the switch is most likely worn out and no longer making proper contact with the terminals when the key is turned to III(START).
If you are feeling ghetto fabulous...
If when the key is turned to II(ON) all the dash lights are functional.
Go under hood and jumper a wire from the positive terminal to the smaller solenoid wire terminal on the starter.
If the starter kicks over no problem and the car starts, then most likely there is an issue with the switch.
Obviously with an AT make sure the car is in P, and with MT make sure the trans is in neutral and the clutch pedal is depressed.
Click on the 'TechAuto' link in my sig, there is a section on Ignition switch.
mike after the first time you turn the key and it goes "click" you get nothing no dash lights no windows no whipers nothing
If you turn the key to the 2 position, yes, the dash lights should be working. If not, it's almost certain the switch is bad so replace it.
ok...now who can tell me what wire does what in the harness i have 5 wires if that helps any....i need to get the car moved before its towed tomorrow dont have the funds to replace the switch looked online for about 30 min trying to find a pin chart to "hotwire" the car to get it home and no luck so can someone help me there?
more than likely bad replace it?...yes but i dont have the funds to replace the switch at the moment and car needs to be moved asap before its towed
well im back replaced ignition switch and the main relay and still nothing coming on no fuel pump buzz no Acc.s 13 volts on the battery any ideas?
bump.....no relays clicking over no dash lights only thing that works are the headlights and door locks please can someone help me out?
Check the under hood fuse box - possible that you shorted something when changing the ign switch.
Next, recheck the battery cables. Both ends of both cables should be clean and tight. Just me but the original issue sounded like a bad battery connection to me....key to on (light elect load) and the dash/dome lights work. Turn the key to start (large elect load) and everything goes dead..........
Clean your battery terminals really well. Both the terminals of the battery and inside the connectors. Additionally, make sure no corrosion has worked its way up the wires.
here's abasic wiring diagram
http://www.the12volt.com/installbay/...tail/1033.html
all the major wires accounted for.
u might have a grounding issue. these hondas have very small ground wires. my lights dim with no radio on, just headlights and a turn signal. look into the Big Three Upgrade or follow my thread on the security/audio/video forum
the original Big Three thread
https://honda-tech.com/forums/audio-security-video-27/power-wire-fuses-holders-%22what-size-do-i-need-%22-big-three-upgrade-pics-details-1952098/
my personal adventure
https://honda-tech.com/forums/audio-security-video-27/power-ground-cables-big-three-upgrade-3218102/
heres a pic of the engine ground cable LMFAO. a little corrosion and this thing is worthless. the other cables are not as small but easily corruptable
That is just one of the many ground cables. The one I'd worry with the most is from the battery. It goes from the ground post to the body and then to the trans.
