F23a1 ecu on f23a possible?
Old 12-14-2020, 05:13 PM
jose david cruZ's Avatar
Default F23a1 ecu on f23a possible?
I recently bought a 98 accord from a seller down in LA he swaped the f23a1 to a Jdm f23a and said he was selling it cuz he needed the money.. it ran kinda funny and he played it off by saying the timing was off because he had taken it to get the timing belt changed witch was true(he gave me the recite of it).. long story short it was not the timing he converted it from obd2b to obd1 And didn’t wire the ecu right because the iacv wasn’t connected at all I just wanted to put back to oem and want to know if I need to get a the Japan ecu or if I can run the f23a1 ecu
Old 12-14-2020, 06:31 PM
99stockcivic's Avatar
Default Re: F23a1 ecu on f23a possible?
Any f23a ECU will work, just go to the junkyard to get one. You don't need a Japanese or other ECU. make sure it come out of the same car type (meaning automatic or manual and 4cyl.
You will then also either need a reporgrammer to program your keys or install a immobilizer bypass chip so it doesn't matter then when you get the ECU plugged in. Otherwise the car will check for you ignition keys to match to the immobilizer and ECU, and they won't.
Immobilizer bypass chip is cheap:
https://www.ebay.com/i/323715606937?...xoCFKsQAvD_BwE
that's what I would do.
Or get a replacement from Ebay, little more, but no dirty work needed.
Old 12-14-2020, 06:39 PM
Thank you sm this car had been a pain to own I just want it to run right. You would know anything on the iacv wiring? it’s black yellow red on the connector and the wires on the harness are balck yellow blue I just wanna make sure I wired it right
Old 04-11-2024, 04:00 PM
2kaccord97's Avatar
Hey did this end up working out for you? I'm having the same problem.
mcole1973
03-16-2011 06:06 PM
nick91civicsi
Engine Management and Tuning
10-25-2009 03:27 PM
gshatch
10
03-20-2009 05:48 PM
5STAR3
03-20-2004 04:40 PM
GimpyAccord
09-26-2002 04:16 PM
Quick Reply: F23a1 ecu on f23a possible?
