5-Lug Conversion
Old 10-09-2004, 11:54 PM
SuShiBoiiii's Avatar
Default 5-Lug Conversion
What is soo good about a 5-Lug conversion? would i still be able to still keep my ABS? And what would u need to do a 5 lug conversion for a 96 accord?
Old 10-10-2004, 01:37 AM
Charri's Avatar
Default Re: 5-Lug Conversion (SuShiBoiiii)
Search Someone already did this
Old 06-19-2005, 10:07 PM
RUBZERK's Avatar
Default Re: 5-Lug Conversion (Charri)
Sorry i had to bring this back to life but i did a search & looked over 32 posts & came up nothing.
Im wondering also. I have disc brakes with ABS.
What do i need to do a 5lug swap & keep the ABS working fine ???
any parts list ?
Old 06-20-2005, 07:14 AM
NAiL05's Avatar
Default Re: 5-Lug Conversion (RUBZERK)
Your ABS should still work after the 5 lug swap. Plus after you get 5 Lug swap you get more wheel choices to choose from.
Old 06-20-2005, 07:45 AM
casmello's Avatar
https://honda-tech.com/zerothread?id=552938
This might help you out.
Old 06-20-2005, 07:49 AM
uncle_el's Avatar
benefits of 5 lug conversion
switch from rotor over hub design... brake changes go from 1-2 hour jobs to 10 minute jobs.
a different selection of wheels... at least ones you can just order at stores, or find on other hondas as oem wheels.
http://www.cb7tuner.com/vbb/showthread.php?t=16241
http://www.accordinglydone.com...tid=1
Old 06-20-2005, 08:47 AM
RUBZERK's Avatar
Default Re: (uncle_el)
Is this exactly what i need to do the swap on my 5th grn with abs ??
front:
1995 Honda Odyssey Knuckles
1995 Honda Odyssey Hubs/Wheelbearings
1997-2001 Integra Type R Brembo Blank Rotors
1993-1996 Prelude VTEC Calipers/Pads
parts used for the rear:
- 1992-1993 Honda Accord EX/SE Rear Disc Knuckles and Trailing Arms
- 1997+ Honda Prelude Hubs and Wheelbearings
- 1996+ Acura Integra Type R Rotors
- 1992-1993 Honda Accord EX/SE Rear Calipers
- 1992-1993 Honda Accord EX/SE Emergency Brake Cables
OmarR
07-23-2013 10:42 AM
OmarR
07-22-2013 11:28 PM
EricUSC
21
04-18-2009 05:40 PM
ILOVEGIRLS
10-18-2003 11:57 AM
Quick Reply: 5-Lug Conversion
