timing belt whine??
Old 02-25-2011, 09:37 PM
elliascool's Avatar
Default power steering pump whine??
so when my car is running accelerating my timing belt has a pretty distinctive whiney noise idk if theres a quick fix or if i have to replace something??
Old 02-25-2011, 09:41 PM
rival12's Avatar
Default Re: timing belt whine??
Are you sure it's the timing belt?
Typically it's the Power Steering Belt or the Alternator/Air Conditioning Belt that squeal.
Old 02-25-2011, 09:56 PM
elliascool's Avatar
yea i acutlay im pretty sur eits the power steering pump/belt , so do i have to change the belts or whats the fix?
Old 02-25-2011, 10:06 PM
elliascool's Avatar
i recently had my power steering flushed and new fluid because it would make noises when turning steering wheel , but it still has the whine when car is running , do i have to replace my power steering pump?
Old 02-25-2011, 11:34 PM
nus_dogg's Avatar
Timing/Balancer Belt whurrs/whines while Serp belt squeals.
I'm pretty sure it's the T-Belt, here's a quick vid to show:
http://www.youtube.com/watch?v=shMCT7yuXpA
If it's the same noise you're getting, do this:
-Remove the upper timing cover
-TDC engine
-Turn the cam gear 3 teeth counter clockwise
-Loosen the tensioner adjusting bolt 2/3 of a turn and retighten.
This should properly tension both the timing and balancer belt. Good Luck!
Please note, I will not be responsible for any of your problems that might occur if you didn't do it right. I recommend you leave it to a mechanic who's more experience.
Old 02-26-2011, 09:05 AM
rival12's Avatar
It has tensioner bolts on it. Tighten it up.
Old 02-26-2011, 03:33 PM
elliascool's Avatar
nah dont sound like that at all its more of a whine the noise when i put my ear close is definitely coming from this
Old 02-26-2011, 06:58 PM
nus_dogg's Avatar
Then the pump is on it's way out.
Old 02-26-2011, 08:37 PM
elliascool's Avatar
so its just the pump i gotta change? thats what i originally thought ... or is there a ghetto fix to it? lol
Old 02-26-2011, 10:17 PM
chikin pickle's Avatar
Directly from the factory service manual, from the section dealing with steering noise.
"Humming due to pulsation of fluid is normal. Particularly with the car stopped and the wheel turned."
kelviiv
09-21-2010 07:47 PM
horseneck
02-11-2009 08:16 PM
Log4n
08-30-2006 03:12 AM
ROOROWNS
06-22-2005 10:19 PM
VTECRaZeR
01-27-2004 10:59 AM
Quick Reply: timing belt whine??
