Rocker arm bolts question
Old 11-27-2012, 04:31 PM
Skatnshawn's Avatar
Default Rocker arm bolts question
Some of my bolts broke during the torquing process, so my question is when I remove them do I need to remove all of them and retorque or will it be ok to remove just those two and torque just those two?
Old 11-27-2012, 04:33 PM
Skatnshawn's Avatar
Default Re: Rocker arm bolts question
If it makes a difference it's the stud bolts on f22b2
Old 11-27-2012, 05:21 PM
GhostAccord's Avatar
To be honest with you, for the extra 10 minutes that it will take, I would loosen all of the bolts and torque them all back down as per the sequence.
Old 11-27-2012, 07:29 PM
Skatnshawn's Avatar
Ok thanks I was leaning towards that but wasn't sure if it was necessary
Old 11-27-2012, 07:30 PM
Skatnshawn's Avatar
Any suggestions on properly torquing the studs? Do they make a wrench for torquing? Besides socket
Old 11-27-2012, 09:10 PM
mudpuppy4life's Avatar
go to your local parts house ( napa auto zone ect.) and see if you can rent a break away torque wrench and look up the torque specks and senquince
Old 11-28-2012, 04:12 AM
Skatnshawn's Avatar
Ok thanks
Old 11-28-2012, 04:17 AM
Skatnshawn's Avatar
Google that wrench looks just like a regular torque wrench that uses sockets, I have one but don't have a socket deep enough to go over stud to the bolt head, however just thought about it and I can put a crows foot on it and get proper torque
Old 11-28-2012, 08:05 AM
Skatnshawn's Avatar
Any idea where I can get valve cover stud/bolts cheaper then through Honda? Don't really wanna spend $40 on 4 bolts but don't want cheap quality either
Old 11-28-2012, 11:32 AM
Junk yard... Studs/bolts from any 90-97 Accord will work.
If you plan on doing more work on your Honda yourself. I would suggest picking up a small 9-10 piece metric deep socket set. 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 15mm, 17mm & 19mm would cover most Honda bots under the hood, and the rest of the chassis for that matter.
As far as putting a crows foot wrench on the end of a tq wrench. Any time you use an extension or crow's foot it will change the torque output of the wrench. There are formulas online for figuring out the actual torque when using a crow's foot.
Old 11-28-2012, 04:15 PM
Skatnshawn's Avatar
Thought about that, but if I go to junkyard they could be weakend from years of use, then possibility of breaking same as mine. Is there any aftermarket companies like arp you know makes these?
Old 11-28-2012, 08:30 PM
How much did you torque them? They should not be stressed all that much, I have reused mine many times without issue.
Old 11-29-2012, 04:30 PM
Skatnshawn's Avatar
Just to specs
Old 12-02-2012, 01:57 PM
TrickshoT_CD5's Avatar
torque all of them down again just to play it safe
Hondalover15
10-08-2012 04:12 PM
D16SohcVtec
06-04-2008 03:52 AM
obliviousSI
10-17-2006 12:34 AM
anothersickhatch
12
06-10-2004 02:26 PM
Madracer1
10
12-19-2002 01:49 PM
Quick Reply: Rocker arm bolts question
