1986-1989 accord engines
Old 01-16-2003, 05:19 PM
accorder's Avatar
Default 1986-1989 accord engines
hi,
I was wondering if there is a difference in engines between the LX, DX, and LX-i models of these years?
Old 01-16-2003, 06:58 PM
cyrixvsp2's Avatar
Default Re: 1986-1989 accord engines (accorder)
huge difference. lxi is fuel injected...the other 2 are carberated or however you spell that. between the lx and dx i have no idea but htere is always a difference. do a search.
Old 01-16-2003, 09:47 PM
89_LXi's Avatar
Default Re: 1986-1989 accord engines (cyrixvsp2)
Yea the main difference was the EFI vs carb'd. The LX-i/SE-i engines were the same (BT for '86/A20A3 for '87-89) and were fuel injected, but there were a few small differences between the 86-87 and 88-89. The DX and LX engines were the same (BS for '86/A20A1 for '87-89), and were carb'd and remained the same for all 4 years. The 88-89 A20A3 got a few tweaks, like a dual stage intake manifold, modified valve timing, 4-2-1 exhaust header instead of 4-1, and they upped the compression ratio from 8.8:1 to 9.3:1. This added 10 hp and 8 ft. lbs of torque.
Specs are:
86-89 DX/LX -- 98 hp/109 ft. lbs torque, 9.1:1 CR, POS 2 bbl Keihin carb
86-87 LX-i -- 110 hp/114 ft. lbs torque, 8.8:1 CR, PGM-FI
88-89 LX-i/SE-i -- 120 hp/122 ft. lbs torque, 9.3:1 CR, PGM-FI
[Modified by 89_LXi, 1:48 AM 1/17/2003]
541delSol
11-20-2018 03:23 PM
civic_minded1987
Honda Civic (2001 - 2005)
40
11-22-2006 03:53 PM
typhoon
02-10-2005 11:38 AM
subgeniusdude
19
03-12-2004 04:21 AM
vtec fan
09-06-2003 06:51 PM
Quick Reply: 1986-1989 accord engines
