Zex 95300/105300 cam valve lash question
Old 09-30-2004, 07:01 AM
Pfieff's Avatar
Default Zex 95300/105300 cam valve lash question
I installed my y8 head the other night with my zex 105300 cam in it and did a valve adjustment. I did it to factory specs of .20mm intake, .25mm exhuast and the valvetrain is louder than hell. I have full ferrea valvetrain. I was wondering what you guys have your valve lash set at with this cam and if it is loud as well. Thanks,
Pfieff
Modified by Pfieffdog at 2:40 PM 9/30/2004
Old 09-30-2004, 07:27 AM
ladysman's Avatar
Default Re: Zex 95300/105300 cam valve lash question (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">I installed my y8 head the other night with my zex 105300 cam in it and did a valve adjustment. I did it to factory specs of .20 intake, .25 exhuast and the valvetrain is louder than hell. I have full ferrea valvetrain. I was wondering what you guys have your valve lash set at with this cam and if it is loud as well. Thanks,
Pfieff</TD></TR></TABLE>
It is loud because you have WAY too loose of settings. Should be .006 and .008.
Edit:
Where the hell did you get those settings at? Did you read the instruction book before installing? (Sorry, had to ask)
Modified by ladysman at 10:38 AM 9/30/2004
Old 09-30-2004, 08:47 AM
Pfieff's Avatar
I just went with OEM valve lash settings, thats what it says right on the hood.
Old 09-30-2004, 09:21 AM
ladysman's Avatar
Default Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">I just went with OEM valve lash settings, thats what it says right on the hood.</TD></TR></TABLE>
Are you sure that is what it says? .20 big.
Old 09-30-2004, 09:29 AM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (ladysman)
For a D16Y8, it's .007" I / .009" E right?
Old 09-30-2004, 09:32 AM
omahaturbocivic's Avatar
Yea thats huge. If I remeber right the range is .008-.011 exhaust and .006-.009 intake. I always use around .006 and .008 but I thought I remeber some of the aftermarket cams need them a few thousanths looser.
Old 09-30-2004, 10:06 AM
ELSpool's Avatar
Even at .007/.009 my car still sounds like a diesel.
Old 09-30-2004, 10:07 AM
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">Even at .007/.009 my car still sounds like a diesel. </TD></TR></TABLE>
I have the same problem.
What clearance should I run then? Tighter?
(completely stock rebuilt head)
Old 09-30-2004, 10:09 AM
ELSpool's Avatar
I wouldn't go tighter, I've heard a few D's with this cam, stock heads to fully built ones, all sound the same.
Old 09-30-2004, 10:40 AM
Pfieff's Avatar
I realize that I put my first post in millimeters and you guys are posting in inches. If you do the conversion, I'm right on where you guys are. Guess they are just going to be loud.
Old 09-30-2004, 01:09 PM
Pfieff's Avatar
So i'm guessing everyone is at the recommending value?
Old 09-30-2004, 02:33 PM
RyanEJ8's Avatar
I think I read somewhere that it has something to do with the lost motion assemblies.
Old 09-30-2004, 05:13 PM
ladysman's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I think I read somewhere that it has something to do with the lost motion assemblies.</TD></TR></TABLE>
It is.
.006 & .008
Old 10-19-2004, 08:40 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
It is.
.006 & .008</TD></TR></TABLE>
Back from the dead, sorry.
I'm at 0.006 intake/0.008 exhaust and it's pretty loud to me. Can I get away with the exhaust a little tighter? Say, 0.006-0.007? Or what would happen if it's too tight?
Old 01-17-2008, 04:22 PM
MeanGreenMachine's Avatar
Default Re: (Finest)
bump.
are any of you guys having problems with this cam? like the lobes being all pitted up and stuff?
Old 01-21-2009, 12:14 PM
97-Civic-Ex's Avatar
http://www.turbod16.com/viewtopic.php?f=26&t=40380
Fighterinsnatch
16
07-26-2007 08:02 AM
hatchedzex
03-22-2006 04:46 PM
mixmastabob
01-23-2005 05:38 PM
CrXr89Si
02-17-2004 11:14 PM
Quick Reply: Zex 95300/105300 cam valve lash question
