Well I figured out my overheating problem.... for those who care
Old 04-05-2003, 01:49 PM
B18EG6's Avatar
Default Well I figured out my overheating problem.... for those who care
I deserve a big ol for this one. When I took my head off today, I noticed that the socket was REALLY stuck on the nut for my ARP studs! Took pliers to get off! (BTW this was a deep 6 point 14mm socket)... Also when I tried to remove them, it was like a torque-wrench effect...... the ratchet would just keep clicking over. I thought my ratchet was dead.
I called a shop and asked why this is happening and they told me I needed a 12 point 1/2" socket!!!!!!
So when I was putting the head on a long time ago, I THOUGHT they were torwued down enough because my torque wrench would slip over like it was supposed to, but in reality it was the socket slipping on the nut.
Turns out my studs were torqued down less that 35 ft/lbs. F@WK me.
Well at least I figured it out.
Anyone know where to get just the nuts for the arp studs?
Old 04-05-2003, 02:14 PM
93LSivic's Avatar
Default Re: Well I figured out my overheating problem.... for those who care (B18EG6)
Jeez, thats a new one for the "Dumbest thing youve done" thread.
Why would you use a 6 point on a bolt that has 12 points and requires a torque setting?
Hope you didnt do the same thing on the rod bolts!
Old 04-05-2003, 03:13 PM
B18EG6's Avatar
Default Re: Well I figured out my overheating problem.... for those who care (93LSivic)
in a hurry i guess...
Old 04-05-2003, 10:38 PM
BrokenVtec's Avatar
you can call ARP to order the nuts....it wont be the cheapest thing.... but i have called them before and they are really helpful.....goodluck
Old 04-05-2003, 11:01 PM
hybridb18's Avatar
haha, damn that sucks, well atleast it was something stupid, and not a cracked head or block or something expensive
Old 04-06-2003, 06:41 AM
Banned
danl's Avatar
Default Re: Well I figured out my overheating problem.... for those who care (hybridb18)
You're going to want to use a flatedge and make sure that the head/block are still flat. The problem you run into when you have a HG leak is the gasses actually erode the alumiumn surfaces away causing a poor sealing surface. Hopefully you won't have to pull the block to re-machine it. Are you using a composite or metal headgasket? You can sometimes get away with approaching the service limits on a composite headgasket, but forget it if you're using a metal one.
Old 04-06-2003, 07:27 AM
turbo Si's Avatar
Default Re: Well I figured out my overheating problem.... for those who care (danl)
I've never seen anything metric come from ARP!
Old 04-06-2003, 05:12 PM
B18EG6's Avatar
Default Re: Well I figured out my overheating problem.... for those who care (turbo Si)
yeh for some reason I didnt think... I thought they used the same size head as the stock ones
Im using a stock headgasket and plan on putting copper spray on it.
Old 04-06-2003, 05:29 PM
boosted hybrid's Avatar
Ah, I was right that the headstuds were loose. Your problems were so similar to mine that I was 95% sure that it was the headstuds. Btw, I have do stupidier stuff. Dont sweat it, its all a learning process.
[Modified by boosted hybrid, 9:30 PM 4/6/2003]
Old 04-06-2003, 10:40 PM
B18EG6's Avatar
Default Re: Well I figured out my overheating problem.... for those who care (boosted hybrid)
thanks...
killacam661
02-11-2010 08:28 AM
95GSRTT
04-30-2005 05:57 PM
99EletronblueSI
10-16-2004 08:25 PM
Tofurky
12-18-2002 05:47 PM
Quick Reply: Well I figured out my overheating problem.... for those who care
