Tial wastegate
Old 10-01-2002, 10:10 AM
blu_si's Avatar
Default Tial wastegate
Alright I can't seem to figure this out. I have a tial 35mm wastegate and a blitz sbc-id boost controller and when i hook it up the way the manual says to (postive pressure from turbo to side of wastegate, and out side of boost controller to top of wastegate) the wastegate is open at idle and opens randomly while driving. EX when the car is at 15-20psi vacuum. Not to mention my wastegate is really freakin loud. If i reverse the way the vacuum lines are hooked up, the wastegate doesn't open, and if i leave just the positive turbo side hooked up and disconnect the line from the tope of the wastegate it opens at 4.5psi. I can't seem to figure out what the deal is. The boost controller works it just seems kinda funny and really loud.
Old 10-01-2002, 02:15 PM
blu_si's Avatar
Default Re: Tial wastegate (blu_si)
ttt
Old 10-01-2002, 02:19 PM
niedejb's Avatar
Try:
Nipple of compressor to "in"
"Out" to side of wastegate (leaving the top open)
This is how I have mine WORKING with my profec.
Old 10-01-2002, 02:25 PM
B*A*N*N*E*D
PeakBoost's Avatar
Default Re: Tial wastegate (niedejb)
vacuum port of wastegate (side) teed to boost/vacuum source and inlet of boost control selonoid
boost port of wastegate (top) to exit of boost control selonoid
also, some of the boost controller selonoids come setup for internal wastegates, so make sure the nipples on your selonoid are setup for external.
[Modified by CHEAPTURBOdotCOM, 11:26 PM 10/1/2002]
Old 10-01-2002, 04:20 PM
blu_si's Avatar
Default Re: Tial wastegate (CHEAPTURBOdotCOM)
I think I tried this before, but i'll give it a go and see what happens thanks
If the above doesn't work then I'll try this way, thanks guys
alperx
01-24-2012 12:22 PM
pv2dickman
05-21-2006 01:35 PM
Firedrake
05-26-2003 07:25 PM
B18C4-T
06-29-2002 01:14 PM
whagkangmakulet
10-01-2001 11:34 AM
Quick Reply: Tial wastegate
