Finally figured out my idle surge, now need advise
Old 11-06-2010, 01:12 PM
skuded's Avatar
Default Finally figured out my idle surge, now need advise
after hours of messing with my turbo gsr's idle surge problems, and hundreds of dollars spent on a new idle air control valve, i finally found the holley tb, that came on my car when i bought it has either bore that isnt perfectly round, or the butterfly is just hanging up somewhere close to fully closed, the car would not surge at idle untill the throttle was hit after starting the car, now that i have found the problem, should i go to a stock gsr throttle body with my skunk 2 intake, or what are my options, im only putting 300 to the wheels, so im pretty sure a stock throttle body will not be a power robber, but any info will be appreciated
Old 11-06-2010, 02:51 PM
komat's Avatar
Default Re: Finally figured out my idle surge, now need advise
if you want bigger you can look into www.maxbore.com with the stock tb
Old 11-06-2010, 09:55 PM
littlewagon's Avatar
Professional Products throttle bodies work great and are inexpensive. They look like and work just like an OEM throttle body. I have had a 68mm on my car for a few years and have installed quite a few with great results. They don't stick like most billet aftermarket throttle bodies because they are cast units and used stamped type linkage identical to OEM.
http://www.professional-products.com/throttleAcura.php
Old 11-09-2010, 04:21 AM
skuded's Avatar
thanks for the advise, however my question is how well does the stock gsr tb flow, will it restrict my flow being that i have forced induction, i am only running 9 lbs out of a sc61, and my intake piping is 2.5inch into a skunk 2 manifold
Old 11-09-2010, 04:33 AM
Chiovnidca's Avatar
You're throttle cable isn't adjusted too tight is it? You should be able to move the cable up and down about 10mm without it moving the throttle blade at all.
Old 11-09-2010, 05:17 AM
skuded's Avatar
no its not the throttle cable, its got plenty of play, once i hit the throttle once after startup, you have to manually press the throttle closed on the tb, for it to close all the way, its just getting hungup at the very end, the car idles great after startup untill you hit the throttle then it wont close all the way
Old 11-09-2010, 12:18 PM
dpetro1's Avatar
stock tb is fine IMO. my car makes 400whp on stock tb with no problems. upgrades are always nice but not required to make power.
Old 11-12-2010, 07:08 AM
skuded's Avatar
well last night after replacing my holley tb with a stock b20 tb and making a custom throttle cable bracket my car idles excellent, im very happy with my car now, it finally after 5 months of working on it drives the way i want it to. im just about done now that i have spent probly 50 hours and about 3 thousand working on it
Old 11-12-2010, 02:15 PM
3minburnout's Avatar
People have made close to 800whp on stock tb,you will be fine.
Dannyx321
10-17-2011 05:40 PM
magicguy
01-30-2009 02:00 PM
longfellahh
10-16-2008 02:35 PM
smkngsr
05-09-2005 07:06 AM
Ink00
12-24-2002 01:15 AM
Quick Reply: Finally figured out my idle surge, now need advise
