Problem with valve keepers/retainers
Old 03-11-2004, 07:45 AM
legendboy's Avatar
Default Problem with valve keepers/retainers
*EDIT* thanks guys, fixed it
I took the valves out of my head (b20b) to get everything a good cleaning before the new block goes in. Problem is there are 4 valves/retainers/keepers (exhaust)that won't stay together! The retainer just keeps popping off the valve! No idea what is wrong, never had this problem before. Any ideas?
Modified by legendboy at 8:21 AM 3/12/2004
Old 03-11-2004, 03:08 PM
legendboy's Avatar
Default Re: Problem with valve keepers/retainers (legendboy)
someones got to be able to help me out
Old 03-11-2004, 04:50 PM
RAWB's Avatar
Are you compressing the valvespring enough. Sometimes the angle when you de-compress the spring/if uneven will make a PITA to keep the keepers in. Are the grooves on the valves where the retainers hold rounded/ maybe the keepers need to be replaced. Just thoughts
Old 03-11-2004, 05:23 PM
sporkcrx's Avatar
Default Re: Problem with valve keepers/retainers (RAWB)
I don't know if it matters but I always keep each valve train matched with each valve it came off of. I can't see how it pops off...maybe the keepers keep separating a little before you release the spring? Put some engine building lube between the two keepers to keep them on the valve, make sure they're in the rut good, and try to slowly release the spring up.
Old 03-11-2004, 05:43 PM
legendboy's Avatar
Default Re: Problem with valve keepers/retainers (sporkcrx)
to put the valves back in i used my hands, thats the way i've always done it. after the retainer is on i give it a couple shots with the end of a hammer to make sure its seated properly. i'm gonna try again with the spring compressor, not sure it gonna make a difference. i also kept the valve with the retainer and keepers together.
Old 03-11-2004, 08:59 PM
sporkcrx's Avatar
How the hell do you do it with your hands?
f22beast
01-17-2010 10:02 AM
EH3forlife
12
01-20-2008 07:55 PM
Quick Reply: Problem with valve keepers/retainers
