Valve/Valve spring installation
Old Jan 14, 2010 | 12:42 PM
f22beast's Avatar
Icon2 Valve/Valve spring installation
Quick question. Should there be any resistance to place a valve in a head?
I installed 14 of the valves/springs with no problem. The last two valves slide in and stop approximatley 1/4" away from the head. I have to tap them in with the soft handle of a mallet.I have to do the same to pop them out. I do not want to install the springs if something is out of line (seals / guides). B16 Head, Stock valves.
They are on the same side of the same cylinder. This makes me think the may have got tapped by the piston and something bent or shifted.
Old Jan 14, 2010 | 12:49 PM
zedron's Avatar
Default Re: Valve/Valve spring installation
Yeah. Doesnt sound right. There shouldnt be that much resistance requiring a hammer to tap them through the guides. Are the valves new? You could just have a slightly bent valve and not a messed up guide. Hopefully that is the case.
Old Jan 16, 2010 | 07:50 PM
dougday84's Avatar
guessing bent.. i'd have them checked and fixed (iffy) or just replace them.
Old Jan 16, 2010 | 08:03 PM
riceburner700's Avatar
probably have bent stems
Old Jan 17, 2010 | 10:02 AM
f22beast's Avatar
I am going to take out two of the installed vlaves and see they go in where the others didn't.
Thanks
for the replies
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
EH3forlife
12
Jan 20, 2008 07:55 PM
B18T3T4
Dec 9, 2006 06:29 PM
TeamCracka
Feb 17, 2004 06:33 PM
95gsr
Oct 7, 2001 08:07 PM
