OBD2-OBD1 injector harness
Could I take the plugs off a set of used OBD2 injectors and solder a set of OBD1 clips to them to make an adapter harness for aftermarket injectors? Does anybody sell these?
Re: OBD2-OBD1 injector harness (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">why not just cut off your obd2 clips and solder on obd1 clips? Its not hard...</TD></TR></TABLE> just wanted to make it a ''plug n play'' affair
Re: OBD2-OBD1 injector harness (turbo0021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo0021 »</TD></TR><TR><TD CLASS="quote"> just wanted to make it a ''plug n play'' affair</TD></TR></TABLE>
check out the prices on that website. I'd much rather solder a few wires than spend over $100 for something like that.
Re: (lkailburn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn »</TD></TR><TR><TD CLASS="quote">u'll still need a resistor box to run em( assumming they're dsm 450's etc)</TD></TR></TABLE>
Aren't most aftermarket injectors "peak & hold" like the OBD1's and the OBD2's are saturated?? Thus the resistor boxes...
Besides, you can pick up a set of clips and resistor box at the junkyard for $10.
Re: (scartail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail »</TD></TR><TR><TD CLASS="quote"> Aren't most aftermarket injectors "peak & hold" like the OBD1's and the OBD2's are saturated?? Thus the resistor boxes...
Besides, you can pick up a set of clips and resistor box at the junkyard for $10.</TD></TR></TABLE>
no there are plenty of saturated aftermarket injectors.
Re: OBD2-OBD1 injector harness (boomslang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomslang »</TD></TR><TR><TD CLASS="quote">http://www.cprracing.com/injectoradpt.htm</TD></TR></TABLE> on this website which part # would i need for a obd2b to obd1 harness?
ever figure this out? Im going from OBD2A to OBD1 (RC ENGINEERING 550CC Saturatred) and want to not hack the harness then hafta unhack (rehack) it when i need to go through inspection.
