Need help witch block and head combo
Old 01-24-2009, 01:11 PM
honda addictions's Avatar
Default Need help witch block and head combo
OK IM BUILDIN A LS TURBO AND WANTED TO KNOW WITCH LS BLOCK SHOULD I GO WITH AND WITCH LS HEAD????
Old 01-24-2009, 02:10 PM
rota92
Guest
Posts: n/a
Default Re: Need help witch block and head combo
*which
My buddy uses B1 stuff FWIW, I'd just use the B18a stuff if you have it laying around. And please use an OBD2 valve cover, those others are god awful haha
Old 01-24-2009, 02:55 PM
rip94delsol's Avatar
a1 sblocks normally have a lil bit more wear on the journals of the crank but besides that either 1 you go with its all the same.
ALthough my a1 block does not have the hole for the black box in the back!
Old 01-24-2009, 08:44 PM
Ls_dx's Avatar
like rota and sol said use whatever you have its all the same... vtec heads are much better tho...
EJ8Squad919
03-04-2013 11:03 PM
91redteg
11-08-2007 03:48 PM
4th-gen-civic
02-15-2007 12:12 PM
rusteds2k
12-02-2003 01:44 PM
AmauryR
11-25-2001 07:09 PM
Quick Reply: Need help witch block and head combo
