NEED HELP...TURBO CRYING..
Old 09-13-2007, 01:24 PM
1fstdc2's Avatar
Default NEED HELP...TURBO CRYING..
I have a t3 t4o3 turbo and everytime i boost my car makes a loud squeel... sounds kinda like a electric drill.. its louder then the turbo when it spools..need help..going to start taking apart car now..
Modified by 1fstdc2 at 2:52 PM 9/13/2007
Old 09-13-2007, 01:27 PM
WHTZ's Avatar
Default Re: NEED HELP...TURBO CRYING.. (1fstdc2)
Feel if you have shaft play...
Old 09-13-2007, 01:28 PM
1fstdc2's Avatar
i dont have any shaft play...spins freely...but at idle shouldnt the wheel be spinning ??
Old 09-13-2007, 01:31 PM
Hondaruss's Avatar
Default Re: (1fstdc2)
Yes the wheel should be spinning at idle
Old 09-13-2007, 01:34 PM
1fstdc2's Avatar
Default Re: (Hondaruss)
Well....Mine is not spinning at idle...it only spins when i rev the car up...any idea on what my be wrong?
Old 09-13-2007, 01:38 PM
Hondaruss's Avatar
What kind of turbo are we talking about. Also does it spin freely if you spin it whith your finger or does it come to a sudden stop?
Old 09-13-2007, 01:46 PM
1fstdc2's Avatar
My turbo is a t3 to4e...when i spin it myself...It doesn't stop but it sometimes gets hard to spin but only for a second.
Old 09-13-2007, 01:51 PM
i ♥ snails
quicksilver1689's Avatar
how did you rig up your lubrication to the tubro? running an oil restrictor? what your oil pressure like?
Old 09-13-2007, 01:56 PM
93supercoupe's Avatar
Default Re: (quicksilver1689)
it should never get hard to spin, and im willing to bet that ebay turbo is toast.
I dunno if its an ebay turbo, i was just foolin.
Old 09-13-2007, 01:58 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: NEED HELP...TURBO CRYING.. (WHTZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHTZ &raquo;</TD></TR><TR><TD CLASS="quote">Feel if you have shaft play... </TD></TR></TABLE>
also check if there is in and out.....thrust bearing play also.
sorry had to do that. he hee.
Old 09-13-2007, 02:18 PM
1fstdc2's Avatar
Default Re: NEED HELP...TURBO CRYING.. (boostedcivicsir)
I have no shaft play at all...I had a tubing coming out of the turbine facing towrads the ground and at the end of the tube i placed a sock. I was boosting and the sock flew off...When I went to go pick it up it was ripped up a bit...Could it have gotten sucked up or something?
Old 09-13-2007, 02:23 PM
CRX T-Si's Avatar
If a turbo is new then it would take a little time before it breaks in before it starts to spin at Idle. or if you have a turbo that has not being used for sometime then it would take some boosting before it spins at Idle.
Quick question, that loud squealing does it sound like a loose belt? did you check your belts?
Never really heard a turbo squeal before...hmm
Old 09-13-2007, 02:26 PM
.RTErnie's Avatar
Default Re: NEED HELP...TURBO CRYING.. (CRX T-Si)
idk what the expletive you guys are talking about not spinning at idle...your **** is messed up.
Squeeling noise...check the turbine housing bolts that connect the turbo to the center section. Makes me think your housing is falling off.
OP...did you drive through The Dalles Oregon within the past two weeks?
Old 09-13-2007, 02:27 PM
1fstdc2's Avatar
No the turbo is not new and I drive my car everyday. something happened when I was boosting...I was in 3rd gear and once I caught full boost and popped it into 4th...this high pitched noise started to happen once I get full boost...It sounds like an electric drill...
Old 09-13-2007, 08:31 PM
krazyhmongboi's Avatar
so i just checked his fins ( im 1fstdc2's brother) and two of them are bent on the tip a little..maybe the sock ripping and allowing something like a small rock in there messed up the fin? would a bend on the tip of the fin make it sound different when spooling?
Old 09-13-2007, 09:43 PM
A.E Motoring's Avatar
Default Re: (krazyhmongboi)
not all turbos spin at idle
Old 09-13-2007, 10:07 PM
DrivinVtec's Avatar
my new turbo spun at idle. how are u feeding the turbo with oil?
Old 09-13-2007, 10:17 PM
Man U FTW
Schister66's Avatar
lack of oil IMO
Old 09-14-2007, 06:08 PM
1fstdc2's Avatar
took turbo to speed factory, and they said that it is gone..=/ so now lookn to buy a new turbo..
jv88_dc2
08-02-2013 05:54 PM
turboman2.2
04-30-2010 07:05 AM
JDM_95_LS
02-27-2008 11:56 AM
blackcrx16
07-30-2007 06:11 AM
19sec beast
11-07-2005 03:44 PM
Quick Reply: NEED HELP...TURBO CRYING..
