+500hp fuel system
Old 04-19-2006, 09:07 PM
95accordh22a's Avatar
Default +500hp fuel system
First off, I have searched this subject. Now I was wondering what kind of fuel system would be good for +500whp with a H22 in a Accord. Will a Walbro 255lph with stock fuel lines be enough or should I atleast upgrade the fuel lines or maybe even the pump? let me know what you guys would run.
Old 04-19-2006, 09:13 PM
adictionbass's Avatar
Default Re: +500hp fuel system (95accordh22a)
you should probably look into running an external pump and maybe a sump setup. Some people push the stock lines farther, but above 500 hp they are close to maxing out. Look into possibly running a -8an line up to the front. (sock line i believe is a -6)
Old 04-19-2006, 10:22 PM
Hybrid_Coupe's Avatar
stock lines...1000cc injectors walboro pump and stock filter here...620hp...Maxed out
Old 04-19-2006, 10:28 PM
tony1's Avatar
Default Re: (Hybrid_Coupe)
The walbro pump will max out before the lines, but yeah, a bit over 600whp is about as far as i'd recommend pushing it.
Old 04-20-2006, 09:28 AM
yep...i wanna go to a sump and external pump set up...thats gunna be in the next off season probably
Old 04-20-2006, 01:36 PM
thanks for the answer guys, looks like ill stay stock lines and the walbro pump with the 1000cc's injectors for now.
Old 04-20-2006, 04:22 PM
morgan@synapse motorsport's Avatar
i was gonna run that same setup, but i decided to do it right the first time. i dont want to have to worry. im sumping the tank and running twin pumps or an eliminator, maybe a weldon
kwah
12-23-2010 06:53 PM
lunatics209
07-26-2007 01:20 PM
boosted96teg
01-31-2007 09:07 PM
turbod da
11-18-2006 09:09 PM
cjb80
06-15-2004 12:21 PM
Quick Reply: +500hp fuel system
