max boost on fmu with stock civic d16 injectors?
Old 02-06-2005, 08:44 PM
Type-X's Avatar
Default max boost on fmu with stock civic d16 injectors?
Would i be able to run on my stock injectors at 8 psi using an fmu? if so, would i need to chip my ecu? or is it better just use the dsm injectors and chip my ecu?
Old 02-06-2005, 09:23 PM
W O T's Avatar
Default Re: max boost on fmu with stock civic d16 injectors? (Type-X)
Atleast pick up an Safc/Vafc for $125 used and some dsm 450's for $50-$60
Itll work perfect for 8psi, then try and borrow a wideband or jump on a dyno for 4-6pulls and do some tuning
There are lots of people running an AFC so getting started is quick and easy
Old 02-06-2005, 11:11 PM
turbopimp's Avatar
You can get away with 8 psi on stock injectors if you run a 12:1 fmu and an inline fuel pump or a walbro 255 hp, but there are probably better options for fuel management out there, unless you already have the fmu and pump.
Old 02-06-2005, 11:34 PM
untitled's Avatar
Default Re: max boost on fmu with stock civic d16 injectors? (turbopimp)
omfg, how many times do people have to say:
**** FMUs. They are a horrible excuse for "fuel managment".
"idiot"
go with a cheap piggback and a set of rx7 460cc injectors i am selling.
Old 02-07-2005, 02:41 AM
liam821's Avatar
Default Re: max boost on fmu with stock civic d16 injectors? (untitled)
When uberdata is free and dsm450cc are $50 - its hard to justify a FMU anymore.
liam
Old 02-07-2005, 07:41 AM
untitled's Avatar
Default Re: max boost on fmu with stock civic d16 injectors? (liam821)
umm... uberdata is about $100 and 450cc injectors are $50. i have 5 sets of 460cc i am selling for $40 a set. 20 ******* injectors are sitting here for this cheap yet i see no one jumping.
Old 02-07-2005, 11:00 AM
Type-X's Avatar
i guess i'll upgrade to 450cc dsm fuel injectors. but i like the piggy back idea better just in case i sell the turbo. any of you guys know if it's possible to convert a cx ecu into a piggy back system for my si cause i got one laying around?
japspecb7
07-22-2008 04:59 PM
spoon95eg
12-19-2005 06:15 PM
boostedlude3g
05-26-2004 01:43 AM
freeplay
12-08-2002 11:03 AM
Giuseppe
10-10-2001 09:23 PM
Quick Reply: max boost on fmu with stock civic d16 injectors?
