Non-intercooled Turbo D16y8 horsepower?
Old 08-24-2001, 12:13 AM
willyboyK20's Avatar
Default Non-intercooled Turbo D16y8 horsepower?
I have a 97 civic ex sedan that i want to make into a sleeper. I want to go turbo and I was wondering, about how much hp at the wheels will the greddy kit give me without a intercooler.
[Modified by willyboyD16, 9:14 AM 8/24/2001]
Old 08-24-2001, 12:50 AM
Better than steak
Arturbo's Avatar
Default Re: Non-intercooled Turbo D16y8 horsepower? (willyboyD16)
You should have around 145-150whp.
art
Old 08-24-2001, 06:16 AM
New User
92CivicSiR's Avatar
Default Re: Non-intercooled Turbo D16y8 horsepower? (Arturbo)
you know you can always put a little side mount intercooler in the area behind your bumper where the resonator box used to be. Just a suggestion, you could get teh best of both worlds.
Old 08-24-2001, 08:34 AM
MDA
New User
MDA's Avatar
Default Re: Non-intercooled Turbo D16y8 horsepower? (92CivicSiR)
or stick a little water cooler under the hood..
Old 08-24-2001, 08:49 AM
New User
dbman96's Avatar
I believe you could fit a T-Bird TC (87-88) or a stock DSM intercooler in that space. Those things are all over Ebay.
Old 08-24-2001, 10:30 AM
Civic TSI's Avatar
Default Re: Non-intercooled Turbo D16y8 horsepower? (dbman96)
I've made 155whp with the greddy kit.
Old 08-24-2001, 11:12 PM
145-150 without an intercooler!! I wasn't expecting that much. That's straight. But I was wondering if any driveablity problems will occur if I don't have a intercooler Also does anyone know the max boost you could run without an intercooler. I've heard that 10psi is, but i don't believe it very much. i didn't know about the dsm i/c, how will i modify the kit's piping to use it or should i just custom make all the piping to fit the dsm i/c.
Old 08-25-2001, 05:53 AM
New User
92CivicSiR's Avatar
If I were you, I would listen to eople suggestions, put some type of charge temp cooler on there. If you get a factory DSM intercooler, you can probably use some of the Greddy piping. If not, then I would go to a muffler shop, and have then bend you up some exhaust piping to use for the time being. I thkn that would work just fine until you could afford to get some custom piping done. I don't think any shop would charge more than like mabey $100 or so to bend that pipe. just a suggestion, I hope this helps a little bit.
Old 08-25-2001, 06:06 AM
DragII's Avatar
get the drag kit, you'll be around the 185-200hp range
PURP
11-06-2009 01:56 PM
DEL97SOL
06-12-2009 12:06 AM
autoxgsr
10-15-2007 11:35 PM
91integraLSVTEC
04-12-2005 09:13 AM
CTL
06-25-2002 10:47 PM
Quick Reply: Non-intercooled Turbo D16y8 horsepower?
