Can i feed both turbo and vtec from oil pressure sensor?
Old 02-11-2010, 10:22 AM
turboman2.2's Avatar
Default Can i feed both turbo and vtec from oil pressure sensor?
Here is my plan i have 2 3/8 npt lines, one will plug direct to the oil pressure plug and 2 1/8npt tees that will be mounted to the firewall, from that tee i will plug in another 3/8th npt oil line that will feed the head, and on the other tee plug in the oil pressure sensor and the turbo feed line. Now the question i have will i be able to provide the pressure needed to bothe the head and turbo with this setup? its like this picture but instead at the top of the tee i will feed the turbo.
Old 02-11-2010, 10:33 AM
boostedEF91's Avatar
Default Re: Can i feed both turbo and vtec from oil pressure sensor?
yes that will work. but its not going to be giving as much oil to the head with having all them T's etc etc. donno how long that will last.. i would invest in a sandwich plate.
Old 02-11-2010, 11:12 AM
BuiltDC2's Avatar
+1 sandwich plate.
Old 02-11-2010, 11:23 AM
unusual71's Avatar
wouldnt be enough flow from that port i wouldn't recommend it.
even the feb '10ers got it, get a sammich plate
Old 02-11-2010, 12:40 PM
accord_raffi's Avatar
All those brass pieces are bound to snap anyway. I would do a sandwich plate for at least one of the two sources needing oil.
Old 02-11-2010, 02:51 PM
TwinCityTuner's Avatar
actually ran that set up on my car before it blew up. id go with the sandwich plate as well. atleast thats how im goin now. spend the extra money itll save you a few bucks down the road
Old 02-11-2010, 06:14 PM
do u recoment feeding the turbo off the oil pressure sensor, or the head?
Old 02-12-2010, 04:58 AM
brian15's Avatar
sandwhich plate.....feed the turbo and head from there. Much cleaner and will save you from possible headaches in the future when all those brass fittings take a dump.
Old 02-12-2010, 05:14 AM
Kyle R's Avatar
Originally Posted by BuiltDC2
+1 sandwich plate.
Old 02-12-2010, 06:18 AM
92redhatch's Avatar
I had 100 issues because of that setup. I switched to a Sandwich adapter and my problems went away. I had to replace my cams and rocker assembly
Old 02-12-2010, 01:09 PM
CerealKiller's Avatar
+1 sandwich plate.
I believe you have your answer.
street_ride14
02-09-2010 07:35 AM
jdkornlp
09-10-2005 06:07 PM
JforJonathan
04-17-2005 10:47 AM
cdog19
02-09-2004 01:15 PM
LudeSi-93
09-21-2001 09:50 AM
Quick Reply: Can i feed both turbo and vtec from oil pressure sensor?
