D-Series Manifold for KKK K26 Turbo
Old 12-21-2002, 11:23 PM
chackoperformance's Avatar
Default D-Series Manifold for KKK K26 Turbo
Anyone have one they willing to sell or can help me find some place to make one?
Thanks
Old 12-22-2002, 12:03 AM
New User
dbman96's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (chackoperformance)
I haven't measured it, but I have a K26 at work and the flange looks REMARKABLY close to a T3 flange... you may be able to just have a standard T3/T4 flanged manifold modified slightly to work. Worth a shot anyway.
Old 12-22-2002, 12:15 AM
shortyz's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (dbman96)
haha no ****.! i got the same turbo! and looking for a mani also.
the bolt holes are 4cm center to center and 8cm center to center
can someone measure a T3 flange for us
Old 12-22-2002, 12:25 AM
shortyz's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (shortyz)
ok heres a pic. cause most people have no idea what my measurements are lol
[Modified by shortyz, 1:25 AM 12/22/2002]
Old 12-23-2002, 12:07 AM
Hm, where would you go to have your manifold made?
Old 12-23-2002, 12:29 AM
shortyz's Avatar
i am going to use an HF manifold and make it fit!
nothing dares to **** with me and my ghetto rigging mind.
Old 12-23-2002, 02:34 AM
BudaKai's Avatar
That turbine housing could use a little cleaning.
Old 12-23-2002, 02:57 AM
miller's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (tzsir)
does anyone know where to get KKK turbo's??? they are the best turbo's in the world hands down....
Old 12-23-2002, 11:39 AM
Lol Shortyz to bad you're in canada or we could blow both our engines side by side with these!
Old 12-23-2002, 11:40 AM
Default Re: D-Series Manifold for KKK K26 Turbo (vtecdoc)
I got mine from a wrecked porsche 944 in a junk yard when I went on a salvaging quest for window motors for school (don't ask) I saw the porsche and almost everything had been pulled but the exhaust manifold/turbo. What sucks is I also need to get a fuel management unit and injectors for this and I'm not sure what ones to use.
So if anyone can help me out there
Old 12-23-2002, 11:53 AM
shortyz's Avatar
yep. i got mine for 30$ at the junkyard.
pretty big.
i gotta go track down some oil lines and fittings and a home made boost controller. ill keep up on this post
Old 12-23-2002, 06:01 PM
cvcc's Avatar
Hi all, is the K26 turbo pretty good? I found one at the local yard. It spins very smooth, better the than my Mitsubishi TD04. Should I keep my TD04 turbo or go w/ K26?
Old 12-24-2002, 05:52 AM
BudaKai's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (cvcc)
Um yea, it's not that simple. How do you want your power-band to look like?
Old 12-24-2002, 06:32 AM
bartek_b's Avatar
i'm gonna be doing my first turbo setup on my friends EF and he bought of my buddie the KKK turbo that was on a 1.8L turbo golf.
The turbo looks really good.
Old 12-24-2002, 09:20 AM
pub
pub's Avatar
shortyz - on my T3 manifold - I measured 8.5cm x 4.5 cm.
Old 12-24-2002, 11:50 AM
boosted3g's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (pub)
The bolt holes are the same as a t3 flange. The problem with most of those turbos is the recessed area that is on the turbo flange. I did a custom kit on an Eclipse and i had to weld it up flat and then took it to a machine shop to be resurfaced..
Old 12-24-2002, 11:51 AM
boosted3g's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (boosted3g)
BTW porsche 911s at one time came with a K26 or K27 turbo.
Old 12-24-2002, 12:24 PM
shortyz's Avatar
yep
i got a turbo map here for the k26 and i mapped out how my motor would spool it.
it wont be fast but the high end looks promising.
3000 rpm itll spool.
i wish i had a scanner i have it all plotted out
also. the one out of the posrche has a differant exhaust side trim (trim right?) on the porsche it will spool more around 4000 rpm. but it pushes boost great.
[Modified by shortyz, 1:25 PM 12/24/2002]
Old 12-26-2002, 06:55 PM
nikitad's Avatar
I'm afraid you are talking about volvo turbos. They have a t3 flange with a round recess.
The T3 flange is 86mm x 45 mm between the boltholes.
Old 12-27-2002, 02:56 PM
boosted3g's Avatar
Default Re: D-Series Manifold for KKK K26 Turbo (nikitad)
The K26 turbos also have the same depression. I am very familiar with the volvo ones and you are correct. This turbo also had the same flange and it was a K26. Either way jsut weld it up, resurface, and it will fit a t3 perfectly.
Old 12-27-2002, 04:10 PM
shortyz's Avatar
i know the recess your talking about. but. why would that make a difference in how it mounts to the plate?
sixgunsound
04-01-2009 02:24 PM
Boostinb20!
12-26-2008 05:37 AM
TsunamiZC
11-12-2008 06:23 PM
rollinlowinthecivic
06-08-2008 12:16 PM
shorsh
04-26-2007 06:09 PM
Quick Reply: D-Series Manifold for KKK K26 Turbo
