Help: Weird Turbo Spooling Sound after Tune
Old 12-30-2005, 01:37 AM
ev0luti0n's Avatar
Default Help: Weird Turbo Spooling Sound after Tune
I noticed that my car made an awful sound when I drove it today. Instead of the spooling sound that the Greddy 18G makes when boosting, it makes a weird clapping sound (like a playing card slapping against a bicycle wheel while moving) best way I could think of describing it. I also can't boost past 5-6 psi no matter what I do with the boost controller. We've checked for vacuum leaks and other things. Does anyone have any suggestions to what it could be? The car was spooling normally this morning making the normal spooling sound.
Old 12-30-2005, 05:25 AM
project dc2's Avatar
Default Re: Help: Weird Turbo Spooling Sound after Tune (ev0luti0n)
take off the filter. check the blades.
Old 12-30-2005, 07:11 PM
ev0luti0n's Avatar
ttt
Old 12-31-2005, 05:41 PM
93turbo16's Avatar
Default Re: Help: Weird Turbo Spooling Sound after Tune (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">take off the filter. check the blades.</TD></TR></TABLE>
Old 12-31-2005, 10:34 PM
Joseph Davis's Avatar
Old 01-01-2006, 12:33 AM
.RTErnie's Avatar
Default Re: Help: Weird Turbo Spooling Sound after Tune (J. Davis)
ruh roh...hope you didn't spend all of your holiday money
Old 01-01-2006, 01:13 AM
D@nnY's Avatar
Default Re: Help: Weird Turbo Spooling Sound after Tune (~RTErnie~)
that noise is the blades of the turbo slapping against the compressor or exhaust housing......it can come apart and get some sweet metal in your motor and expletive your bearings as well you might want to take it off NOW
Old 01-01-2006, 04:35 AM
fiend44's Avatar
Default Re: Help: Weird Turbo Spooling Sound after Tune (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">that noise is the blades of the turbo slapping against the compressor or exhaust housing......it can come apart and get some sweet metal in your motor and expletive your bearings as well you might want to take it off NOW </TD></TR></TABLE>
Old 01-01-2006, 07:48 AM
AbitAvenger's Avatar
So did you check the blades yet?
Old 01-01-2006, 02:10 PM
SlowB16si's Avatar
Default Re: (AbitAvenger)
I was just going to make a topic about this same thing. I just took off the filter and the blades are fine and theres no shaft play or anything weird. could it just be im hearing my injectors? they are 550's and I know some people hear then tick pretty good.
Old 01-02-2006, 12:27 AM
.RTErnie's Avatar
Default Re: (SlowB16si)
we told him to take off his compressor housing and turbine housing and look at the blades. No where did we say, "take off your filter and take a look at your blades."
reason why....you cant see the whole blade. It could look perfectly fine from the inducer side and be completly destroyed on the exducer side.
Modified by ~RTErnie~ at 7:24 PM 1/2/2006
Old 01-02-2006, 11:02 AM
D@nnY's Avatar
yes on the compressor side you will only see the smaller inducer side
on the turbine side you will only see the smaller exducer
Old 01-04-2006, 01:25 AM
ev0luti0n's Avatar
well thanks everyone for the help. today i took off turbo looked at everything. i couldn't figure out what could be making the sound. anyway i put it back together put it on the car. When i took it back out for a spin the sound disappeared. Lucky me. Hope it stays like this. woot woot.
McLude2nR
12-20-2006 10:39 AM
wantboost
01-27-2006 11:22 AM
turbotegrar
05-05-2004 09:55 PM
Brian-Brian
06-02-2003 03:05 PM
Quick Reply: Help: Weird Turbo Spooling Sound after Tune
